(42) AR=XPD Antenna Axial Ratio (dB) <> Antenna Cross Polarization Isolation (dB)
11-10-2022, 08:54 PM (This post was last modified: 11-10-2022 09:11 PM by Emilio Abud Filho.)
(42S) Antenna Axial Ratio (dB) <> Antenna Cross Polarization Isolation (dB) Conversion
Dear All
Program for converting Antenna Axial Ratio (dB) <> Antenna Cross Polarization Isolation (dB); to be used with "HP Solver" built-in application.
- Program documentation, including example, math equations, how to use explanations, source code, etc; (pdf)
- RAW format file (zip)
00 { 62-Byte Prgm }
01 LBL "AR=XPD"
02 MVAR "ARdB"
03 MVAR "XPD"
04 RCL "ARdB"
05 20
06 ÷
07 10↑X
08 STO "ARFAT"
09 1
10 -
11 1
12 RCL+ "ARFAT"
13 ÷
14 LOG
15 20
16 ×
17 RCL+ "XPD"
18 END
Warm regards,
Attached File(s)
.zip  AR=XPDraw.zip (Size: 176 bytes / Downloads: 4)
.pdf  HP-42S Program Documentation Form - AR=XPD_v100.pdf (Size: 185.86 KB / Downloads: 7)
Emilio Abud Filho
Mobile: +55 (41) 9 9172-1201
e.abud@uol.com.br
emilio.abud.filho@gmail.com
