(42) BORDA - Edge illumination angle equation for an on-axis parabolic antenna
11-14-2022, 02:16 PM
Dear All
Solving the simple edge illumination angle equation for an on-axis parabolic reflector antenna, (the angle seen from its focal point or feeder phase center); to be used with "HP Solver" built-in application. Attachments: - Program documentation, including example, math equations, how to use explanations, source code, etc; (xlsx and pdf) - Source code in RAW format file (zip) Code:
Warm regards, Emilio Abud Filho Mobile: +55 (41) 9 9172-1201 e.abud@uol.com.br emilio.abud.filho@gmail.com |
