(42) D2L - Minimum far field distance for antenna test range
11-14-2022, 10:43 PM
Dear All
Calculating the minimum far field distance for antenna test range, based on antenna aperture size and operation frequency; to be used with "HP Solver" built-in application. Attachments: - Program documentation, including example, math equations, how to use explanations, source code, etc; (xlsx and pdf) - Source code in RAW format file (zip) Code:
Warm regards, Emilio Abud Filho Mobile: +55 (41) 9 9172-1201 e.abud@uol.com.br emilio.abud.filho@gmail.com |
