RREF with complex numbers not working properly
11-15-2022, 03:20 PM
(This post was last modified: 11-15-2022 03:21 PM by AnalogJoe.)
I have a singular matrix with complex numbers:
first row: [-0.3-0.6i, -0.6] second row: [0.75, 0.3-0.6i] if I use RREF with my Prime I get the identity matrix, which is not correct, making the same input in Matlab gives me the correct result which is [1, 0.4-0.8j; 0, 0]. Any ideas? |
11-15-2022, 11:27 PM
RE: RREF with complex numbers not working properly
Try:
rref([[−0.3-0.6*i,−0.6],[0.75,0.3-0.6*i]],1) -road |
11-16-2022, 05:03 AM
RE: RREF with complex numbers not working properly | |||
11-16-2022, 12:48 PM
11-16-2022, 12:52 PM
Hmmm, it appears tha in exact mode you don't need the 1:
rref([[(-3-6*i)/10,-6/10],[75/100,(3-6*i)/10]]) also works. -road |
11-17-2022, 11:11 PM
Thank you! I will take a look.
