Free42 OVER stack operation
11-28-2022, 05:20 AM
(This post was last modified: 11-28-2022 05:23 AM by kostrse.)
Hi Thomas,
Would you consider adding OVER stack operation from the HP 50g? Existence of such operation makes big difference between having to use a temporary variable/register and just using pure stack. There're are other extended stack operations in HP 50g which would be nice to have but OVER is the first which would be great having. |
11-28-2022, 06:30 AM
RE: Free42 OVER stack operation
I don't use either the 42 or the 50g; but could you do something like RCL Y ?
http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 ) |
11-28-2022, 06:46 AM
Yes, RCL ST Y has the same effect as OVER.
11-28-2022, 07:14 AM
(This post was last modified: 11-28-2022 07:22 AM by Thomas Klemm.)
Here are some others:
SWAP: X<>Y DUP: RCL ST X | ENTER DROP: R↓ | CLX + OVER: RCL ST Y ROT: X<>Y X<> ST Z UNROT: X<> ST Z X<>Y NIP: X<>Y R↓ TUCK: X<>Y RCL ST Y 2DUP: RCL ST Y RCL ST Y 2DROP: R↓ R↓ 2SWAP: R↓ R↓ Not all of them do exactly what they do on the HP-50g. I couldn't come up with a simple DROP that saves X in LASTX and duplicates T. But often that is not needed. |
11-28-2022, 07:19 AM
Free42 and Plus42 have a set of stack operations, which I believe covers all the stack functions in the 48 series. See https://thomasokken.com/free42/#big-stack
11-28-2022, 01:11 PM
(This post was last modified: 11-28-2022 01:38 PM by Thomas Okken.)
SWAP: X<>Y
DUP: DUP DUP2: DUPN 2 DUPN: DUPN n DROP: DROP DROP2: DROPN 2 DROPN: DROPN n OVER: RCL ST Y ROT: R↑N 3 UNROT: R↓N 3 ROLL: R↑N n ROLLD: R↓N n |
11-29-2022, 05:14 AM
Thank you for explanation!
I could not figure out how to enter RCL ST Y from the calculator keyboard but I found that PICK 2 is basically the same thing as OVER. |
11-29-2022, 05:21 AM
RE: Free42 OVER stack operation | |||
11-29-2022, 05:42 AM
