New set of skins for HP Prime Virtual calculator
11-30-2022, 08:36 PM (This post was last modified: 11-30-2022 08:36 PM by Spybot.)
I'm glad to share this new set of skins for the HP Prime Virtual calculator, these were made all 100% vectors. I hope you like them.
INSTRUCTIONS:
- I assume you have the latest virtual emulator version (2021 10 1).
- Each skin has 4 files, you will do the following for each skin.
1.- Unzip skin file.
2.- Copy the 4 files to this location: Documents\HP Prime\Skins
3.- Enjoy!
Attached File(s)
.zip  Vertical Small.zip (Size: 373.94 KB / Downloads: 65)
.zip  Horizontal Medium.zip (Size: 393.62 KB / Downloads: 44)
.zip  Horizontal Large.zip (Size: 598.35 KB / Downloads: 54)
Spybot.
11-30-2022, 09:28 PM
RE: New set of skins for HP Prime Virtual calculator
Very nice. Just a small suggestion: enlarge the screen on the Vertical_Small a bit to be more representative of the actual size. Awesome work, many thanks for your effort!
12-01-2022, 12:23 AM
Hi calc_freak!
Yes, believe me I tried for the vertical version several different screen sizes (maintaining the aspect ratio) between the small and the medium size, but all of them showed things incorrectly, I don't know if it's a glitch from the emulator or something. So I decided to assign the original 320 x 240px screen size to the vertical version, this size does show things perfectly fine as well as the 640 x 480px for the medium size and the 960 x 720px size for the large version.
Spybot.
12-01-2022, 03:18 AM
No worries, you did some great work. Thanks again!
