Approximations for the Logarithm Function
12-02-2022, 09:33 AM
Numerical Integration of the Reciprocal Function
We use several numerical methods to calculate the integral in this formula for the logarithm: \( \begin{aligned} \log(1+x) = \int_{1}^{1+x}\frac{1}{t}\,dt \end{aligned} \) These approximations are then compared to its Taylor series: \( \begin{aligned} \log(1+x) = x - \frac{x^2}{2} + \frac{x^3}{3} - \frac{x^4}{4} + \frac{x^5}{5} - \frac{x^6}{6} + \frac{x^7}{7} + \mathcal{O}(n^8) \\ \end{aligned} \) Anyone familiar with the HP-41C/HP-42S will recognise the LN1+X function. The difference in the coefficients of the first deviating term is calculated and can be used to compare the methods. Also for the example \( x = 0.2 \) the approximation is compared with the true value: Code: from math import log1p 0.18232155679395462 Furthermore, for each approximation, a program for the HP-42S is provided with the result of the calculation for the same value. Conclusions Adding intervals in the case of the trapezoidal or midpoint rule brings us closer to the true coefficients of the third-order term. However, Simpson's 1/3 rule reduces the error to a 5th order term, while its complexity is similar to the others. We can improve this a bit with Simpson's 3/8 rule, but we can't change the order of magnitude. Using Gaussian quadrature, the constants are not integers anymore, but for 2 points the formula is similar. Adding one more point reduces the error to a 7th order term. When integrating a function numerically, choose your sampling points carefully. References Trapezoidal Rule \( \begin{aligned} \int_{a}^{b}f(x)\,dx &\approx \sum_{k=1}^{N}\frac{f(x_{k-1})+f(x_{k})}{2}\Delta x_{k} \\ &= \frac{\Delta x}{2}\left(f(x_{0})+2f(x_{1})+2f(x_{2})+2f(x_{3})+2f(x_{4})+\cdots +2f(x_{N-1})+f(x_{N})\right) \\ \end{aligned} \) 1 Interval \( \int_{a}^{b}f(x)\,dx \approx (b-a)\cdot {\tfrac {1}{2}}(f(a)+f(b)) \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx \frac{x}{2}\,\left[1 + \frac{1}{1+x}\right] \\ &= x - \frac{x^2}{2} + \frac{x^3}{2} + \mathcal{O}(x^4) \\ \end{aligned} \) Difference \( \begin{aligned} \frac{1}{2} - \frac{1}{3} = \frac{1}{6} \approx 0.166667 \end{aligned} \) Example Code: I = x/2*(1+1/(1+x)) (0.18333333333333335, 0.18232155679395462, 0.005549407086964257) Program Code: 00 { 13-Byte Prgm } 0.183333333333 0.182321556794 2 Intervals \( \begin{aligned} \int_{a}^{b}f(x)\,dx \approx \frac{1}{2}\frac{b-a}{2} \left[f(a) + 2f\left(\frac{a+b}{2}\right) + f(b)\right] \end{aligned} \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx \frac{x}{2 \cdot 2}\,\left[1 + 2 \cdot \frac{2}{1+1+x} + \frac{1}{1+x}\right] \\ &= \frac{x}{4}\,\left[1 + \frac{4}{2+x} + \frac{1}{1+x}\right] \\ &= x - \frac{x^2}{2} + \frac{3 x^3}{8} + \mathcal{O}(x^4) \\ \end{aligned} \) Difference \( \frac{3}{8} - \frac{1}{3} = \frac{1}{24} \approx 0.0416667 \) Example Code: I = x/4*(1+4/(2+x)+1/(1+x)) (0.1825757575757576, 0.18232155679395462, 0.0013942442477620518) Program Code: 00 { 22-Byte Prgm } 0.182575757576 0.182321556794 Midpoint Rule \( \begin{aligned} \int_{a}^{b}f(x)\,dx \approx \Delta x\left[f\left(a+{\tfrac {\Delta x}{2}}\right)+f\left(a+{\tfrac {3\Delta x}{2}}\right)+\ldots +f\left(b-{\tfrac {\Delta x}{2}}\right)\right] \end{aligned} \) 1 Interval \( \begin{aligned} \int_{a}^{b}f(x)\,dx\approx (b-a)\cdot f\left(\frac{a+b}{2}\right) \end{aligned} \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx x \, \frac{2}{2+x} \\ &= \frac{2x}{2+x} \\ &= x - \frac{x^2}{2} + \frac{x^3}{4} + \mathcal{O}(x^4) \\ \end{aligned} \) Difference \( \frac{1}{4} - \frac{1}{3} = - \frac{1}{12} \approx -0.0833333 \) Example Code: I = 2*x/(2+x) (0.18181818181818182, 0.18232155679395462, -0.0027609185914404585) Program Code: 00 { 9-Byte Prgm } 0.181818181818 0.182321556794 2 Intervals \( \begin{aligned} \int_{a}^{b}f(x)\,dx\approx \frac{b-a}{2}\,\left[f\left(\frac{3a+b}{4}\right) + f\left(\frac{a+3b}{4}\right)\right] \end{aligned} \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx \frac{x}{2}\,\left[\frac{4}{3+1+x} + \frac{4}{1+3+3x}\right] \\ &= 2x\,\left[\frac{1}{4+x} + \frac{1}{4+3x}\right] \\ &= x - \frac{x^2}{2} + \frac{5 x^3}{16} + \mathcal{O}(x^4) \\ \end{aligned} \) Difference \( \begin{aligned} \frac{5}{16} - \frac{1}{3} = - \frac{1}{48} \approx -0.0208333 \end{aligned} \) Example Code: I = 2*x*(1/(4+x)+1/(4+3*x)) (0.1821946169772257, 0.18232155679395462, -0.0006962414042590937) Program Code: 00 { 20-Byte Prgm } 0.182194616977 0.182321556794 Simpson's Rule 1/3 rule \( \begin{aligned} \int_{a}^{b}f(x)\,dx &\approx \frac{1}{3} h \,\left[f(a)+4f\left(\frac {a+b}{2}\right)+f(b)\right]\\ &=\frac{b-a}{6}\,\left[f(a)+4f\left(\frac{a+b}{2}\right)+f(b)\right] \end{aligned} \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx \frac{x}{6}\,\left[1 + 4 \frac{2}{1+1+x} + \frac{1}{1+x}\right] \\ &= \frac{x}{6}\,\left[1 + \frac{8}{2+x} + \frac{1}{1+x}\right] \\ &= x - \frac{x^2}{2} + \frac{x^3}{3} - \frac{x^4}{4} + \frac{5 x^5}{24} + \mathcal{O}(x^6) \\ \end{aligned} \) Difference \( \begin{aligned} \frac{5}{24} - \frac{1}{5} = \frac{1}{120} \approx 0.00833333 \end{aligned} \) Example Code: I = x/6*(1+8/(2+x)+1/(1+x)) (0.18232323232323233, 0.18232155679395462, 9.189968027780061e-06) Program Code: 00 { 22-Byte Prgm } 0.182323232323 0.182321556794 3/8 rule \( \begin{aligned} \int _{a}^{b}f(x)\,dx &\approx \frac{3}{8}h\,\left[f(a)+3f\left(\frac{2a+b}{3}\right)+3f\left(\frac{a+2b}{3}\right)+f(b)\right]\\ &= \frac{b-a}{8}\,\left[f(a)+3f\left(\frac{2a+b}{3}\right)+3f\left(\frac{a+2b}{3}\right)+f(b)\right] \\ \end{aligned} \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx \frac{x}{8}\,\left[1 + 3 \frac{3}{2+1+x} + 3 \frac{3}{1+2+2x} + \frac{1}{1+x}\right] \\ &= \frac{x}{8}\,\left[1 + \frac{9}{3+x} + \frac{9}{3+2x} + \frac{1}{1+x}\right] \\ &= x - \frac{x^2}{2} + \frac{x^3}{3} - \frac{x^4}{4} + \frac{11 x^5}{54} + \mathcal{O}(x^6) \\ \end{aligned} \) Difference \( \frac{11}{54} - \frac{1}{5} = \frac{1}{270} \approx 0.00370370 \) Example Code: I = x/8*(1+9/(3+x)+9/(3+2*x)+1/(1+x)) (0.18232230392156862, 0.18232155679395462, 4.097856705131325e-06) Program Code: 00 { 33-Byte Prgm } 0.182322303922 0.182321556794 Gauss–Legendre Quadrature \( \begin{aligned} \int_{-1}^{1}f(x)\,dx\approx \sum _{i=1}^{n}w_{i}f(x_{i}) \end{aligned} \) 2 Point \( \begin{array}{|c|c|} \hline \text{Point} & \text{Weight} \\ \hline -\frac{1}{\sqrt{3}} & 1 \\ \hline +\frac{1}{\sqrt{3}} & 1 \\ \hline \end{array} \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx \frac{x}{2}\,\left[\frac{1}{1 + \left(\frac{1}{2} - \frac{1}{\sqrt{12}}\right)x} + \frac{1}{1 + \left(\frac{1}{2} + \frac{1}{\sqrt{12}}\right)x}\right] \\ &= x\,\left[\frac{1}{2 + \left(1 - \frac{1}{\sqrt{3}}\right)x} + \frac{1}{2 + \left(1 + \frac{1}{\sqrt{3}}\right)x}\right] \\ &= x - \frac{x^2}{2} + \frac{x^3}{3} - \frac{x^4}{4} + \frac{7 x^5}{36} + \mathcal{O}(x^6) \\ \end{aligned} \) Difference \( \begin{aligned} \frac{7}{36} - \frac{1}{5} = - \frac{1}{180} \approx -0.00555556 \end{aligned} \) Example Code: from math import sqrt (0.18232044198895028, 0.18232155679395462, -6.114499151613408e-06) Program Code: 00 { 29-Byte Prgm } 0.182320441989 0.182321556794 This variant uses registers: 1 ENTER 3 SQRT 1/X - STO 00 1 LASTX + STO 01 Code: 00 { 18-Byte Prgm } 0.182320441989 0.182321556794 3 Point \( \begin{array}{|c|c|} \hline \text{Point} & \text{Weight} \\ \hline -\sqrt{\frac{3}{5}} & \frac{5}{9} \\ \hline 0 & \frac{8}{9} \\ \hline \sqrt{\frac{3}{5}} & \frac{5}{9} \\ \hline \end{array} \) \( \begin{aligned} \int_{1}^{1+x}\frac{1}{t}\,dt &\approx \frac{x}{2 \cdot 9}\,\left[\frac{5}{1 + \left(\frac{1}{2} - \sqrt{\frac{3}{20}}\right)x} + \frac{8 \cdot 2}{1+1+x} + \frac{5}{1 + \left(\frac{1}{2} + \sqrt{\frac{3}{20}}\right)x}\right] \\ &= \frac{x}{9}\,\left[\frac{5}{2 + \left(1 - \sqrt{\frac{3}{5}}\right)x} + \frac{8}{2+x} + \frac{5}{2 + \left(1 + \sqrt{\frac{3}{5}}\right)x}\right] \\ &= x - \frac{x^2}{2} + \frac{x^3}{3} - \frac{x^4}{4} + \frac{x^5}{5} - \frac{x^6}{6} + \frac{57 x^7}{400} + \mathcal{O}(x^8) \\ \end{aligned} \) Difference \( \begin{aligned} \frac{57}{400} - \frac{1}{7} = - \frac{1}{2800} \approx -0.000357143 \end{aligned} \) Example Code: from math import sqrt (0.18232155441457765, 0.18232155679395462, -1.3050442389081796e-08) Program Code: 00 { 46-Byte Prgm } 0.182321554415 0.182321556794 This variant uses registers: 1 ENTER 0.6 SQRT - STO 00 1 LASTX + STO 01 Code: 00 { 34-Byte Prgm } 0.182321554415 0.182321556794 |
12-02-2022, 07:42 PM
RE: Approximations for the Logarithm Function
We should compare sum with trapezoids vs squares, with same function evaluations (not intervals)
To simplify, we let t=s*x+1, to get integration limit from 0 to 1. RHS integral value is simply averaged height of its integrand. \(\displaystyle \ln(1+x) = \int_1^{1+x} \frac{1}{t}\,dt= \int_0^1 \frac{x}{x\,s + 1}\,ds \) For midpoint rule with 3 function evaluation, we trisect intervals. lua> function f(s) return x/(x*s+1) end lua> x = 0.2 lua> log1p(x) 0.18232155679395465 Trapezoidal Rule, and squares equivalent: lua> t1 = (f(0) + f(1))/2 lua> t2 = (t1 + f(1/2))/2 lua> t1, t2 0.18333333333333335 0.18257575757575759 lua> s1 = f(1/2) lua> s2 = (s1 + f(1/6) + f(5/6))/3 lua> s1, s2 0.18181818181818182 0.1822650467811758 Simpson 1/3 rule, and squares equivalent: lua> t2 + (t2-t1)/(4-1) -- weight = {1,4,1} / 6 0.18232323232323233 lua> s2 + (s2-s1)/(9-1) -- weight = {3,2,3} / 8 0.18232090490155006 Simpson 3/8 rule, and squares equivalent: lua> require'fun'() lua> function acc(s,x,y) return s+x*y end lua> function dot(x,y) return foldl(acc,0,zip(x,y)) end lua> dot({f(0/3),f(1/3),f(2/3),f(3/3)}, {1,3,3,1}) / 8 0.18232230392156865 lua> dot({f(1/8),f(3/8),f(5/8),f(7/8)}, {13,11,11,13}) / 48 0.18232121889089584 For ∫(1/x), sum with squares avoided edge bias, converge slightly better. |
