trajectory modeling in the flight path coordinate system
12-05-2022, 11:01 AM
This HP PPL program demonstrates how to model the trajectory of an aerospace vehicle in the flight path coordinate system. This example flies an STS maximum cross range re-entry trajectory using angle-of-attack and bank angle information extracted from a trajectory optimization program.
The initial flight path coordinates can be defined by the user according to the following example. Please note the units of each input.
// define initial flight path coordinates
// altitude (kilometers)
xalt := 121.92;
// relative velocity (kilometers/second)
vrel := 7.80288;
// geographic declination (degrees)
dec := 0.0;
// geographic longitude (degrees)
elon := 0.0;
// azimuth (degrees)
azim := 90.0;
// flight path angle (degrees)
fpa := -2.39780555815067;
The final simulation time, in seconds, can be set by the user in line 180 of the source code.
// final simulation time (seconds)
tf := 1000.0;
The software and documentation for this program can be downloaded at
https://www.dropbox.com/s/nj4kpk4kowlqj6...s.zip?dl=0
