95LX - booting into DOS
12-18-2022, 02:37 AM
Does anyone know how I can make a 95LX boot straight into DOS instead of the app manager? I haven't used mine in a while and now I can't remember, but I know there was a way...
12-18-2022, 04:26 AM
C:\AUTOEXEC.BAT
Edit or create the autoexec.bat file and don’t let it start the system.
12-18-2022, 04:46 AM
RE: 95LX - booting into DOS
I don't have a 95LX, but if it helps on the 200LX you can hit the ALT key at boot and it will pop-up a dialog asking which drive you want to boot from. The default is the ROM drive on D:. Choosing C: will get you a plain DOS session.
If you want the normal path and drivers loaded, copy autoexec.bat from D: to C: and remove the System Manager load command "200" from the last line. --Aaron |
12-18-2022, 12:01 PM
I've created c:\autoexec.bat and just put prompt $p$g in there, but it doesn't do anything, still boots straight into manager.
My main 200LX does work like that, but not the 95LX... |
12-20-2022, 02:59 AM
(This post was last modified: 12-20-2022 10:02 AM by polbit.)
For other that might be looking for the same answer:
You have to create C:\CONFIG.SYS file, and add: Code: shell = command /p Code: echo off Unfortunately @echo off doesn't work with this DOS version, but cls clears echo off fast enough that you won't notice. |
12-23-2022, 07:03 PM
HP 95LX DOS details from developer's guide
I was mistaken to suggest editing the AUTOEXEC.BAT. The full details are explained well on page 2 of the HP 95LX Developer's Guide in chapter 3 (It's only 2 pages long).
Quote:The Default Shell |
