HP49-HP50: string search in many programs
01-10-2023, 03:51 PM
(This post was last modified: 01-29-2023 01:01 AM by Gil.)
A)
Supposing you are in a directory Dir with many programs P1, P2,..., Pn. Suppose that, for all of them, you want to check if you have the instruction/command DUP. B) Normal procedure: 'P1' RCL and look for DUP 'P2' RCL and look for DUP 'P3' RCL and look for DUP 'P...' RCL and look for DUP 'Pn' RCL and look for DUP. C) To avoid errors, here is a small program, with 2 arguments to be entered: - the list of the programs {P1, P2,..., Pn} to be searched in your actual directory Dir - the string "DUP" to be searched inside P1, P2,..., Pn. The output: A full list {P5, P7..., Pm} among the given programs {P1, P2,..., Pn} where the given string "DUP" was found. \<< "2 Arg: - list of prog to examine - searched string" DROP SWAP DUP SIZE \-> str L L.s \<< { } 1 L.s FOR i L i GET RCL \->STR str DUP SREPL SWAP DROP 0 > IF THEN L i GET + END NEXT DUP SIZE R\->I "'" str + "' in " + SWAP + " of " + L.s R\->I + " Prog/Var" + \->TAG \>> \>> Or « "2 Arg: - list of prog to examine - searched string" DROP SWAP DUP SIZE str L L.s « { } 1 L.s FOR i L i GET RCL —>STR str DUP SREPL SWAP DROP 0 > IF THEN L i GET + END NEXT DUP SIZE R—>I "'" str + "' in " + SWAP + " of " + L.s R—>I + " Prog/Var" + TAG » » D) Save that small program, say in directory TOOLS (as it is the case for me), under name 'FIND'. Assume that the above directory TOOLS is under directory HOME1. Assume, further, that HOME1 directory is under main direct HOME. E) Let's assign, now, the LS+F key to the above program in order to be able to use it whereever we are in a directory, say STZT. Write then in your calculator (in bold the commands I forgot to copy in the original post, with my apologies): \<< PATH \-> p \<< HOME HOME1 TOOLS 'FIND' RCL p EVAL EVAL \>> \>> not forgetting to finish by the following instruction: 16.2 ASN By the way It is s a good idea to execute a RCLKEYS and save, separately, the resulting list in your computer/phone (in case of EMU48 crash...). Regards, Gil Campart |
01-11-2023, 08:49 AM
RE: HP49-HP50: string search in many programs
I think this programme does what you want:
Code: Size: 78.00 Store the programme in HOME, enter the directory of interest, type string of interest & actuate the programme to return list of items including the given string. |
01-11-2023, 10:19 AM
(This post was last modified: 01-11-2023 03:44 PM by Gil.)
Interesting program, Gerald, but not at all "straightforward" for me as a simple user.
More for specialists who are at ease using such command as BINT, POSCHAR, etc. Of course, it's most compact. Congratulations! |
