HP-41CX Halfnut problem cardreader with Nov64d
01-16-2023, 03:36 PM
Hi all,
as stated in the subject i have a problem with a Nov64d module and my cardreader:
The Nov64d has Hepax, CCD-OSX and MATH rampages E and F are free. I tried other configs and modules as well.
If I plug in the cardreader and insert a card i always get a checksum error. I cannot read any card.
I tried another cardreader with Firmware 1F but the behaviour is the same. When i unplug the Nov64d module i can read every card!
I seems to me, that the speed changes a bit (quicker).
This is only on a HP-41CX halfnut, but not on a fullnut machine. I have two halfnuts, for both the same situation.
Can anyone explain that or tell me how to fix it?
Ralf
01-21-2023, 09:27 PM
RE: HP-41CX Halfnut problem cardreader with Nov64d
Hi Ralf,
This may be related to the differences from Half/Fullnuts power supply. Being the halfnuts a bit weaker than the fullnuts.
The demanding card reader motor can cause a dropout in the power line (V+) affecting the functionality of the NoV-64d and causing noise in the bus, which renders the "CHECKSUM ERR".
Again, I don't have a Card Reader or a Halfnut here, but you can check if the problem persist when configuring your NoV-64d in a Clonix-D fashion; this saves a few mAmps and may help the Card Reader to perform as expected.
Also, trying new fresh batteries or external power will give a glimpse of the power supply behaviour.
Sorry not being of much help on this, I've got very limited resources here. I can offer a much detailed diagnosis once I get back home next month.
Best wishes.
Diego.
"Do not suppose, check it twice."
01-23-2023, 11:53 AM
Hi Diego,
thanks for reply, this is not a big thing, since i am using the cardreader not very often.
In this case i had an old program on mag cards only for calculating LM317 voltage regulators.
I pulled the Nov64d out and could read the cards. Now i put the program on Hepax memory and don't need the cardreader nay more. I only thought the cardreader or the HP-41 may be defective.
Ralf
