how do you get special characters in posts
12-21-2013, 08:43 PM
In the old forum, I used links to a special page in the hpmuseum site to get special characters like divide, sigma, and square root. Since this new forum has more formatting options, is there a way to get these special characters without using those special codes now?
12-21-2013, 09:12 PM (This post was last modified: 12-21-2013 09:18 PM by Mark Hardman.)
RE: how do you get special characters in posts
(12-21-2013 08:43 PM)Don Shepherd Wrote:  In the old forum, I used links to a special page in the hpmuseum site to get special characters like divide, sigma, and square root. Since this new forum has more formatting options, is there a way to get these special characters without using those special codes now?
The new forum supports inserting \({LaTeX}\) expressions.
See the LaTeX? and Forum Thumbs Up! threads for more information.
Mark Hardman
Ceci n'est pas une signature.
12-21-2013, 09:58 PM
Mark Hardman
Thanks Mark. I really don't want to learn a whole new language, I just want to be able to insert a sigma, square root, divide, or multiply symbol. Isn't there a quick and easy way to do that? Latex looks like it is used for complicated math expressions. My needs are much simpler.
12-21-2013, 10:17 PM
See my suggestion at the bottom of
this thread.
You can invoke 'charmap' by holding down the windows key and hitting 'r', then type in charmap.
-katie
12-21-2013, 11:33 PM
(12-21-2013 09:58 PM)Don Shepherd Wrote:  I just want to be able to insert a sigma, square root, divide, or multiply symbol.
Copy and paste from the following Unicode characters:
Mark Hardman
12-21-2013, 11:51 PM
Mark Hardman
OK, thanks Mark. I copied those to the clipboard, pasted them in a Notepad document, saved it with Unicode encoding, and was successfully able to copy from that document and paste in the forum post. That's a solution that will work for me.
12-22-2013, 02:52 AM (This post was last modified: 06-18-2014 06:07 PM by Don Shepherd.)
Well, after much email exchange with Katie, here is what I found:
Terminators backslash left paren and backslash right paren do not center text on the line, which is what I want normally. Terminators dollar dollar and dollar dollar center text on the line.
The following codes must be surrounded by backslash ( and backslash )
backslash sum gives a large sigma
backslash Sigma gives a small sigma (capital S is required)
backslash div gives a division symbol
backslash times gives a multiply symbol
backslash sqrt{2B+1} puts 2B+1 under the radical
backslash sqrt{} gives just the radical symbol, nothing underneath it
