(HP-41) strange behaviour, needs repair
02-27-2023, 09:43 AM (This post was last modified: 02-27-2023 09:55 AM by Hiwi.)
i recently bought a very nice looking HP-41C serial 2130A.. from ebay. The seller said, that it is fully working.
The calculator looks like new, never been serviced, but does not work correctly:
You can do normal calculations, SIN, COS ... I think that is what the seller has tested. But I
can't enter any programs.
Switching to PGM mode shows a NONEEXISTENT message. SIZE 000 ,0049 0063 is working and i can access and store data in the registers. But no program.
When USER mode is on, i can make calculations but not SIN,COS,TAN in this case ALPHA turns on, and i can see the KEYCODES! Switching OFF returns to nomal display.
GTO... does not work either, i see forever 'ACKING _ ' instead of PACKING. SAME with function XEQ PACK.
Is the CPU faulty or ROM, can I do some other checks, PSU?
RAM should be ok, since I can store data in different SIZE options and make KEY assignments.
In case it is not repairable, has anyone a spare mainboard for sale?
Ralf
02-28-2023, 11:47 AM
RE: (HP-41) strange behaviour, needs repair
someone gave me the hint to clone the sevice rom into the nov64, and this shows the ERROR 3 ROM 0 BAD.
I am once more very enthused what a great engineer performance this little HP41 was given to.
It was made to last forever. :-)
Ralf
02-28-2023, 02:49 PM
Hi Ralf,
(02-27-2023 09:43 AM)Hiwi Wrote:  In case it is not repairable, has anyone a spare mainboard for sale?
There is a store in Spain which normally sells 41 motherboards (but out of stock right now) ...
Full-nut motherboards
Cheers,
[35/45/55/65/67/97/80 21/25/29C 31E/32E/33E|C/34C/38E 41C|CV|CX 71B 10C/11C/12C/15C|CE/16C 32S|SII/42S 28C|S 48GX/49G/50G 35S 41X]
03-01-2023, 10:03 PM
have a look at your private message
Günter
03-20-2023, 10:12 AM
SOLVED: (HP-41) strange behaviour, needs repair
Hi all,
the problem is solved. i got replacement parts from a member of this forum. Thanks again.
I changed the ROM0 chip from the working board to be sure that it was the only fault and now it works again.
Ralf
/41/48/
