step-by-step solving/simplifying
03-11-2023, 02:11 PM
Hi
Is it possible to see the steps when simplifying or solving an equation?
Thanks for your help!
Devi
03-12-2023, 02:13 AM
RE: step-by-step solving/simplifying
Unless you solve the equation manually, no.
03-13-2023, 08:00 AM
(03-12-2023 02:13 AM)Eddie W. Shore Wrote:  Unless you solve the equation manually, no.
Thank your for your reply, Eddie.
A pity. I understand that the requirements for this should be available. There just seems to be no implementation then.
I tried a Ti CX2 that can do it. But I could never get used to the terribly cumbersome handling of the Ti. The HP is literally "prime" for me in terms of usability and interface.
04-13-2023, 10:59 AM
You could turn simplification to Minimum ( CAS -settings - Simplify:Minimum), then use simplify command to do it further.
