Graph memos with hp50g
03-20-2023, 08:08 AM
I was wondering if it is possible to store graphs with the hp50g permanently and then print them on the hp 82240b infrared printer(assuming I can print them);
with the method given by the instructions you store the graph in the stack but then it is not manageable by the printing procedure and also it is erased after power off.
03-21-2023, 01:44 AM
RE: Graph memos with hp50g
Have a look at the ->LCD and LCD-> commands in the manual. These let you capture the screen as a bitmap grob which can be saved to a variable like any other object.
03-21-2023, 02:19 PM
Or, if I understood correctly the query:
After having the graph drawn for the first time:
1) Chose EDIT (E-key below the graph)
2) NEXT NEXT (two times)
3) Chose PICT-> (C-key below the graoh)
4) ON (kind of escape)
Then appear the words "Graphic 131 ×..."
Then 5) 'A' STO (you save it under A, for instance).
