(DM 42) Bernoulli and tangent numbers
03-20-2023, 08:06 PM (This post was last modified: 03-21-2023 10:58 AM by Gjermund Skailand.)
B2n, Tn: Fast calculation of Bernoulli numbers based on Tangent numbers
Input: n
output: result in register 0 to n, even Bernoulli numbers b2n
note b1= +/-0.5, all other odd numbers=0. For b1 the latest definition is +0.5
can also provide Tangent numbers depending on flag 00
flag 00 cancelled: Calculate even Bernoulli numbers B2n
flag 00 set : calculate tangent numbers Tn
flag is reset after each run
runs in standard 4 stack mode, uses registers 0-n and flag 00
Calculates Bn60 (n=0..30) in less than a second on batteries.
On USB power, calculates up to n=999, i.e. the 0-1998th Bernoulli numbers in about 5min 40 seconds.
Ref
"Fast computation of Bernoulli, Tangent and Secant Numbers. "
Richard P. Brent and David Harvey
6 Algorithms based three-term recurrences
arXiv:1108.0286v3 [math.CO] 5 Sep 2011
The algorithm is stable, and should return Bernoulli numbers accurate to 31-32 digits
2022-03-20 DM-42 version Gjermund Skailand
00 { 126-Byte Prgm }
01▸LBL "Tn"
02 SF 00
03▸LBL "B2n"
04 1ᴇ3
05 ÷
06 2
07 +
08 ENTER
09 ENTER
10 1
11 STO 01
12 1
13▸LBL 00
14 ×
15 STO IND ST Y
16 RCL ST Y
17 IP
18 ISG ST Z
19 GTO 00
20 R^
21▸LBL 01
22 ENTER
23 ENTER
24 ENTER
25 1
26 -
27 R↓
28 RCL IND ST T
29▸LBL 02
30 RCL ST Y
31 RCL- ST T
32 ×
33 2
34 RCL+ ST L
35 RCL× IND ST Z
36 +
37 STO IND ST Y
38 ISG ST Y
39 GTO 02
40 R↓
41 R↓
42 ISG ST X
43 GTO 01
44 FP
45 1
46 STO 00
47 +
48 FS?C 00
49 RTN
50▸LBL 03
51 ENTER
52 IP
53 RCL× IND ST X
54 2
55 LASTX
56 STO+ ST X
57 DSE ST X
58 Y^X
59 ÷
60 LASTX
61 STO+ ST X
62 1
63 -
64 ÷
65 FS? 00
66 +/-
67 FC?C 00
68 SF 00
69 STO IND ST Y
70 R↓
71 ISG ST X
72 GTO 03
73 CF 00
74 END
Attached File(s)
.zip  B2n.zip (Size: 1.18 KB / Downloads: 3)
03-22-2023, 08:46 AM
RE: (DM 42) Bernoulli and tangent numbers
The same, but using a matrix to store the numbers, so you can easily go beyond 999 ;-)
Also, I prefer not to use flags.
input 30 XEQ "B2n" runs in 0.57 seconds on batteries.
00 { 121-Byte Prgm }
01▸LBL "Tn"
02▸LBL 10
03 1
04 NEWMAT
05 EDIT
06 LASTX
07▸LBL 02 @ Tk    k
08 STOEL
09 ISG ST Y
10 X<>Y
11 RCL× ST Y
12 I+
13 FC? 76
14 GTO 02
15 2
16▸LBL 03
17 0
18 RCLEL
19 I+
20 FS? 76
21 GTO 00
22▸LBL 04 @ Tj-1 j-k k
23 X<>Y
24 STO× ST Y
25 2
26 +
27 X<>Y
28 RCLEL
29 RCL× ST Z
30 +
31 STOEL
32 DSE ST Y
33 I+
34 FC? 76
35 GTO 04
36 R^
37 1
38 STOIJ
39 +
40 GTO 03
41▸LBL "B2n"
42 XEQ 10
43 EDIT
44 CLX
45▸LBL 05
46 +/-
47 ENTER
48 SIGN
49 STO+ ST X
50 +
51 RCLEL
52 2
53 RCL ST Z
54 ABS
55 Y^X
56 X^2
57 LASTX
58 -
59 ÷
60 ×
61 STOEL
62 R↓
63 I+
64 FC? 76
65 GTO 05
66▸LBL 00
67 RCLEL
68 EXITALL
69 END
Cheers, Werner
41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE
03-22-2023, 11:45 AM
Hi Werner,
shorter and nicer (as usual), and you found a nice way to avoid the loop limit of 999.
PS I wasn't happy about the flag use either :-)
br Gjermund
