How to use a forward function declaration in a program ?
12-21-2013, 09:19 PM
I know this must be obvious can't figure it out. I have a subroutine called by a main program that I want to move to the end of the end of the main program as follows:
EXPORT Sub1;
EXPORT Main_prog
Begin
Sub1;
End;
Sub1
Begin
End;
I'm getting a syntax error just before the Begin after the Sub1. What am I doing wrong?
12-21-2013, 09:54 PM
RE: How to use a forward function declaration in a program ?
First export isn't necessary, but "()" is needed otherwise is a variable.
Sub1();
EXPORT Main_prog
Begin
Sub1;
End;
Sub1
Begin
End;
My website: ried.cl
12-21-2013, 10:01 PM (This post was last modified: 12-21-2013 10:04 PM by Michael de Estrada.)
That doesn't work either. Now I get a syntax error after the ) on the first line.
Edit, it does work w/o the EXPORT, but gives the syntax error with the EXPORT.
12-21-2013, 10:05 PM
I would try:
Sub1();
EXPORT Main_prog()
Begin
Sub1();
End;
Sub1()
Begin
End;
Or
EXPORT Sub1();
EXPORT Main_prog()
Begin
Sub1;
End;
EXPORT Sub1()
Begin
End;
Or
Sub1()
Begin
End;
EXPORT Main_prog()
Begin
Sub1();
End;
by the way, be consistent with EXPORT
Patrice
“Everything should be made as simple as possible, but no simpler.” Albert Einstein
12-21-2013, 10:11 PM
This works, thanks guys:
PHP Code:
Sub1();
EXPORT Main_prog
Begin
Sub1
End;
Sub1
Begin
End
