[Programming] Proper Tail Recursion - Bypass recursion limit
03-27-2023, 08:37 PM
(This post was last modified: 03-28-2023 08:16 AM by FernandoMorea.)
My research on how to bypass hp prime's recursion limit, coupled with my studies of lisp and haskell, led me to this solution: saving the continuation of a function in a variable, that will be returned to the user, the user must re-run the result to iterate the process.
To cheat the static analysis of the CAS that triggers the recursion limit, we must also define a fake function that simply calls back the main function. The function must be tail recursive: Let's recall what a tail recursive function looks like, let's take the factorial and python as toy language: Code:
So now let's go to our HP PRIME: Code:
Another example could be the algorith for Polynomial long division Code:
03-28-2023, 06:18 AM
(This post was last modified: 03-28-2023 07:21 AM by FernandoMorea.)
RE: [Programming] Proper Tail Recursion - Bypass recursion limit
To test the code try with:
myfact(10,1) long({1,2,3},{4,5,6}) To continue to run the result you can either copy the last result from the top with the arrow key and run it with enter, or you can do: eval(Ans) - Or, better, you can write: cont After that, you can spam the enter key to run the continuation till the end of the algorithm (in the case of the factorial you have exactly n iteration, so if you wrote myfact(100,1) you should spam the enter key for 100 times, still not practical but it works). |
03-28-2023, 07:27 AM
