HP49-HP50 Exact Distance calculator
03-29-2023, 08:47 PM (This post was last modified: 03-29-2023 08:51 PM by Gil.)
The other day I tried to get the second point P2,
when having an initial point P1
and giving a distance s (between P1 and that new point P2) together with a bearing alpha1.
But then I discovered that some commands disappeared (replaced by "external...") in program P1—>P2.
Here is a somewhat fixed version
that seems to work again.
Attached File(s)
.hp  DISTANCE.6d.hp (Size: 18.09 KB / Downloads: 8)
