HP-3468 case parts available
04-03-2023, 03:13 PM
The HP-3468 HP-IL Digital Voltmeter came in a plastic case.
Its plastic handle is somewhat fragile and can break.
The same plastic case was used for other HP instruments and also by other manufacturers.
I came across a broken 3rd party instrument which used this case.
The case itself has specifically machined openings and connector cutouts and its own front panel. It is not usable as a replacement part.
But I can offer these parts:
- handle (complete with both aluminum cover disks)
- two "rubber" feet (which are held in the case by three nipples)
- four long screws with washers which connect the two shell halves
- four black plastic spacers which hold the PCB in place
This might be interesting for you, if you have a 3468 with a broken handle or missing parts.
You pay shipping costs (the parts are located in Germany - overseas shipping costs may be excessive).
