HP-15C LE: Error with i ^ -i
08-15-2014, 08:19 PM
Since one week I'm a proud owner of a HP-15C LE!
I discovered an error in computing of complex numbers not found in the simulator on Windows: If I try to compute i ^ -i I get Error 4. What does the original HP-15C do with this task? Does it compute the correct value e ^ (pi / 2)? Regards Burkhard |
08-15-2014, 08:30 PM
RE: HP-15C LE: Error with i ^ -i
Do you happen to have USER activated?
Cheers Thomas |
08-15-2014, 08:39 PM
(This post was last modified: 08-15-2014 09:08 PM by Mark Hardman.)
(08-15-2014 08:19 PM)BuSchu Wrote: Since one week I'm a proud owner of a HP-15C LE! [ETA: See my correction below.] On the original 15C, I get 1,0 after a short pause. I immediately get 1,0 on the 15C LE. Ceci n'est pas une signature. |
08-15-2014, 08:52 PM
RE: HP-15C LE: Error with i ^ -i | |||
08-15-2014, 09:07 PM
(This post was last modified: 08-15-2014 09:09 PM by Mark Hardman.)
(08-15-2014 08:52 PM)Thomas Klemm Wrote:(08-15-2014 08:39 PM)Mark Hardman Wrote: On the original 15C, I get 1,0 after a short pause. Ugh. Forgot to SF 8. On both the original 15C and 15C LE the answer is 4.8105. You are right. It is most likely that the OP was in User mode trying to execute a non-existent LBL D. Ceci n'est pas une signature. |
08-15-2014, 09:56 PM
(08-15-2014 09:07 PM)Mark Hardman Wrote:(08-15-2014 08:52 PM)Thomas Klemm Wrote: Using the Nonpareil emulator I get 4.8105. Which appears to be the correct answer. Yes you are right! It was the User mode! Thank's! Regards Burkhard |
