Make a retro scientific calculator with LED display and mechanical keypad.
04-11-2023, 11:05 AM
Hi Guys, for several years, I am seeking a scientific calculator with a big screen and keyboard and never found one, so I decide to make a retro one. the simple way is using a calculator ASIC and connecting it to LEDs and a mechanical keypad. Unfortunately, there are too few chips with LED output directly, so I should make a LCD to LED converter first. After doing the first test, it runs OK. It's not an emulator but a "real" machine. Here is the prototype of the calculator with the original PCB. The next step is to integrate all the parts into a whole PCB, and add mechanical keys, wish you like it.
and here is a short video: |
04-14-2023, 06:02 PM
RE: Make a retro scientific calculator with LED display and mechanical keypad.
That's pretty nice. Maybe add a macropad for the keys. Will it be RPN?
05-04-2023, 03:11 PM
(This post was last modified: 05-09-2023 02:00 AM by geekvan.)
RE: Make a retro scientific calculator with LED display and mechanical keypad. | |||
05-05-2023, 02:49 AM
(05-04-2023 03:11 PM)geekvan Wrote: the 1st integrated pcb worked finally. If you ever sell a kit, I'm in! Tom L Cui bono? |
05-08-2023, 09:13 AM
05-13-2023, 10:46 AM
(This post was last modified: 05-13-2023 10:51 AM by geekvan.)
here is the final prototype without enclosure.
![]() ![]() ![]() ![]() https://www.youtube.com/shorts/Iv_z6_ydeSI all the sources can be found here: https://github.com/geekvan007/retro_sharp506 |
05-13-2023, 01:53 PM
Very nice indeed! Does the calculator chip have to come from a salvaged calculator?
05-13-2023, 02:36 PM
05-13-2023, 03:03 PM
(This post was last modified: 05-13-2023 03:18 PM by EdS2.)
Aha - looks like quite a few manufacturers used that chip (Edit: but these are programmable, which is confusing me):
Quote:Used in: ASTOR: 2, ATABA: AT687, AURORA: TB607, CANON: F300, CITIES: 8700, CITIZEN: SRP145, CITIZEN: SRP40, DYNA-TONE: G3/8700, IBICO: 098, INTERTRONIC: SC88P, KNIGHT: K31A, MBO: 610PR (version-1), MBO: 820PR, PIRACOMP: PR40, PIRACOMP: PR80, PRIVILEG: LC650PR, RADIO SHACK: EC4021, RADIO SHACK: EC4036, WHIRLPOOL: CW201Also apparently Levis and Shangji. Edit: is it the 42-key SHARP EL-506P we need? I see there was a 506A and 506H too, with different number of keys. If so, there's a list of 20 clones here. Edit: this is confusing! Quote:With the replicas of the chip used in EL-506P, the first „clones” was built in similar housing as used in EL-506H, at various factories in Hong Kong, Taiwan and China. Later, with similar appearance and same model number, a simple programmable calculators based on a genuine Sharp chip — which was made for Sanyo — completed. |
05-13-2023, 03:56 PM
(05-13-2023 03:03 PM)EdS2 Wrote: Aha - looks like quite a few manufacturers used that chip (Edit: but these are programmable, which is confusing me): It seems that the chip LI3301A is used for OEM manufacturers only. All SHARP calculators that use this chip are clones (fake). I bought many used calculators with this chip that have different suffixes, including 506P/506H/514. Also, I heard that this chip has a clone one which was made by a Vietnam company. |
05-13-2023, 09:35 PM
I sure like those keys.
http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, http://wilsonminesco.com/links.html ) |
05-13-2023, 11:34 PM
Looks great and thanks for sharing your project.
But one feature is distracting and it is the blue LED MEM indicator. |
06-18-2023, 04:35 AM
Geekvan,
Who's the source of your keytops? And standard Cherry keyswitches? Bill |
06-19-2023, 02:53 PM
(06-18-2023 04:35 AM)bwiese Wrote: Geekvan, Hi Bill, keytops were bought from China Taobao: blank xda and printed xda number keys. https://item.taobao.com/item.htm?id=676692151586 https://item.taobao.com/item.htm?id=685502367565 and the key is compatible with Cherry MX. |
