Integral Step by Step Solver for HP Prime
04-14-2023, 09:11 PM
EXPORT IndefiniteIntegration()
BEGIN // Set up program variables LOCAL f, int, choice; // Prompt the user to enter the function to be integrated TextOut(1,1,"Enter the function to be integrated:"); f:=CAS(INPUT()); // Prompt the user to choose the integration method TextOut(1,2,"Choose the integration method:"); TextOut(1,3,"1. Substitution"); TextOut(1,4,"2. Integration by parts"); TextOut(1,5,"3. Partial fractions"); TextOut(1,6,"4. Trigonometric substitution"); TextOut(1,7,"5. Integration by inspection"); choice:=INPUT(); // Use integration by substitution to find the indefinite integral IF choice=1 THEN int:=SubstitutionIntegration(f); // Use integration by parts to find the indefinite integral ELSEIF choice=2 THEN int:=IntegrationByParts(f); // Use partial fractions to find the indefinite integral ELSEIF choice=3 THEN int:=PartialFractionIntegration(f); // Use trigonometric substitution to find the indefinite integral ELSEIF choice=4 THEN int:=TrigSubstitutionIntegration(f); // Use integration by inspection to find the indefinite integral ELSEIF choice=5 THEN int:=InspectionIntegration(f); ELSE // Display an error message if an invalid choice is entered TextOut(1,8,"Error: Invalid choice"); RETURN; END; // Display the intermediate steps and the final result TextOut(1,8,"Indefinite integral:"); TextOut(1,9,STRING(int)+"+C"); END; // Helper function for substitution integration EXPORT SubstitutionIntegration(f) BEGIN LOCAL u, v, du, dv, int; u:=CAS(Str("u=",SubstVar(f))); v:=Int(Simplify(f/SubstVar(f))*SubstVar(f),SubstVar(f)); dv:=CAS(Deriv(v,SubstVar(f))); du:=CAS(Deriv(u,SubstVar(f)))*CAS(Deriv(SubstVar(f))); int:=Simplify(SubstVar(f)*v-Int(v*dv/SubstVar(f))-Int(u*du,SubstVar(f))); // Display the intermediate steps TextOut(1,10,"Step 1: Let u = "+STRING(u)); TextOut(1,11,"Step 2: Find dv/d"+STRING(u)+" = "+STRING(dv)); TextOut(1,12,"Step 3: Find v = "+STRING(v)); TextOut(1,13,"Step 4: Substitute into the integral:"); RETURN Simplify(int); END; // Helper function for integration by parts EXPORT IntegrationByParts(f) BEGIN LOCAL u, v, du, dv, int; u:=FirstVar(f); v:=Int(Simplify(f/u),u); dv:=CAS(Deriv(v)); du:=CAS(Deriv(u)); int:=Simplify(u*v-Int(v*du)-Int(u*dv)); // Display the intermediate steps TextOut(1,10,"Step 1: Let u = "+STRING(u)); TextOut(1,11,"Step 2: Let dv = "+STRING(dv)); TextOut(1,12,"Step 3: Find v = "+STRING(v)); TextOut(1,13,"Step 4: Substitute into the integral:"); RETURN Simplify(int); END; // Helper function for partial fraction integration EXPORT PartialFractionIntegration(f) BEGIN LOCAL pf, int; pf:=PartialFraction(f); int:=0; FOR i FROM 1 TO Size(pf) DO int:=int+Simplify(Int(pf[i]/pf[i][1])); END; // Display the intermediate steps TextOut(1,10,"Step 1: Find the partial fraction decomposition:"); FOR i FROM 1 TO Size(pf) DO TextOut(1,10+i,STRING(pf[i])+" = "+STRING(pf[i][1])+" / ("+STRING(pf[i][2])+")"); END; TextOut(1,10+Size(pf)+1,"Step 2: Integrate each term:"); RETURN Simplify(int); END; // Helper function for trigonometric substitution integration EXPORT TrigSubstitutionIntegration(f) BEGIN LOCAL u, v, du, dv, int, choice; // Prompt the user to choose the trigonometric substitution TextOut(1,10,"Choose the trigonometric substitution:"); TextOut(1,11,"1. x = a*sin(u)"); TextOut(1,12,"2. x = a*tan(u)"); TextOut(1,13,"3. x = a*sec(u)"); choice:=INPUT(); // Use the selected trigonometric substitution to find the indefinite integral IF choice=1 THEN u:=CAS(Str("u=asin(x/a)")); v:=Int(Simplify(f*Cos(u))/a,u); int:=Subst(v,SubstVar(f),u); // Display the intermediate steps TextOut(1,15,"Step 1: Let x = a*sin(u)"); TextOut(1,16,"Step 2: Find dx/d"+STRING(u)+" = "+STRING(a*Cos(u))); TextOut(1,17,"Step 3: Substitute into the integral:"); ELSEIF choice=2 THEN u:=CAS(Str("u=atan(x/a)")); v:=Int(Simplify(f*Sec(u)^2)/a,u); int:=Subst(v,SubstVar(f),u); // Display the intermediate steps TextOut(1,15,"Step 1: Let x = a*tan(u)"); TextOut(1,16,"Step 2: Find dx/d"+STRING(u)+" = "+STRING(a*Sec(u)^2)); TextOut(1,17,"Step 3: Substitute into the integral:"); ELSEIF choice=3 THEN u:=CAS(Str("u=acos(x/a)")); v:=Int(Simplify(f*Sin(u)*Sec(u))/a,u); int:=Subst(v,SubstVar(f),u); // Display the intermediate steps TextOut(1,15,"Step 1: Let x = a*sec(u)"); TextOut(1,16,"Step 2: Find dx/d"+STRING(u)+" = "+STRING(a*Sin(u)*Sec(u))); TextOut(1,17,"Step 3: Substitute into the integral:"); ELSE // Display an error message if an invalid choice is entered TextOut(1,15,"Error: Invalid choice"); RETURN; END; RETURN Simplify(int); END; // Helper function for integration by inspection EXPORT InspectionIntegration(f) BEGIN LOCAL int; int:=Int(f); // Display the intermediate steps TextOut(1,10,"Step 1: Recognize the integral:"); TextOut(1,11,"Step 2: Integrate the recognized form:"); RETURN Simplify(int); END; Permanently banned |
06-03-2023, 06:08 PM
RE: Integral Step by Step Solver for HP Prime
hi, unfortunately this is not working, i keep getting syntax errors all over the code :/
