9100B with smoked zener
04-17-2023, 11:45 PM
Hi All,
I recently got back to work on my non-working 9100B that I bought several years ago. I found a smoked zener diode on the ROM address driver board. It measured 0 ohms before unsoldering it then broke while I was extracting it. Problem is the color bands are burned beyond recognition. Anybody have an idea what Vz or Vcol is? Vcol = -(15 - Vz). Thanks for any assistance! Richard |
04-18-2023, 03:49 AM
RE: 9100B with smoked zener | |||
04-18-2023, 04:34 AM
Thanks but no. The rom address driver board is not included in those schematics.
04-18-2023, 05:21 AM
I was trying to see where -Vcol went but I couldn't find it on the schematics. Maybe it could provide a clue to the zerer voltage.
cheers Tony |
04-18-2023, 08:30 AM
04-19-2023, 12:17 AM
Thanks Tony & Bushcat,
Here's where Vcol goes. It's the array of transistors that are part of the multi-layer ROM board. That voltage doesn't appear on board 12 plug 1. It provides the voltage & current to drive the columns and for design purposes needs to be something less than -15 volts. For some reason I can't attach pictures. Look on the Tony Duel schematic labeled "Address Drivers 09100-66567" for the references to Vcol. |
04-19-2023, 01:27 AM
(This post was last modified: 04-19-2023 01:28 AM by teenix.)
Not much to go on looking at the circuit.
Maybe someone with one of these can get a number from the matching part and it may be listed somewhere. Or (probably a long shot) if someone has a dead machine, perhaps take the part off the board and measure the breakdown voltage using a voltmeter, adjustable DC supply and series resistor. cheers Tony |
