HP 41c with X-FUNCTION
04-23-2023, 06:21 AM
hi all
just a question about the X-FUNCTION module. I have a 41c with quad memory, total registers are 320. if I add one X-FUNCTION to this 41C, the registers are still 320 as maximum? in another words, the X-FUNCTION module could be in 41C with quad memory or not? thanks! BR, bai |
04-23-2023, 09:15 AM
RE: HP 41c with X-FUNCTION
It's separate. You can definitely use it with the quad memory module, but XMem is more like a hard disc, and is file-oriented. It does not extend your normal memory. The X-Fcn module has 126 registers, but two are used for the header of each file; so if you only had one file, you'd have 124 registers available for it. In general, n files offer 126-2n registers for you to use. If you add two XMem modules (or a double one, which is rare, but I have one), you'll have 600 registers.
http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 ) |
04-23-2023, 09:28 AM
(04-23-2023 09:15 AM)Garth Wilson Wrote: It's separate. You can definitely use it with the quad memory module, but XMem is more like a hard disc, and is file-oriented. It does not extend your normal memory. The X-Fcn module has 126 registers, but two are used for the header of each file; so if you only had one file, you'd have 124 registers available for it. In general, n files offer 126-2n registers for you to use. If you add two XMem modules (or a double one, which is rare, but I have one), you'll have 600 registers. Understood, Thank you for your reply! |
