(48g/49/50) Matrix Permanent
04-28-2023, 06:02 PM
(This post was last modified: 01-07-2024 08:03 PM by John Keith.)
NOTE: This program is obsolete. It has been replaced by the program in post #5 which is much more efficient.
This program computes the permanent of a square matrix. The matrix may be real or complex, and on the 49 and 50, may also be exact integer or symbolic (type 29). This program is slow because computing permanents is slow. It is not practical for matrices larger than 8 x 8, and a 7 x 7 matrix may take several minutes on the physical calculator. The program uses recursive Laplace expansion as described in this section of the Wikipedia link above. For matrix (or sub-matrix) size 2 x 2, the explicit formula is used, requiring only two multiplications and one addition. This method requires about half as many multiplications as the "brute force" method based on the definition of the permanent. The program should be stored in a variable named 'PRMNT'. If another name is used, the name reference in the program must be changed. Code:
A shorter version for the 49 and 50: Code:
Some examples: This 7 x 7 1/0 matrix from A000794 returns 24 in about 4 minutes on my 50g. Code:
A symbolic permanent: Code:
04-28-2023, 10:44 PM
RE: (48g/49/50) Matrix Permanent
Hi, For a 5-line HP-71B recursive subprogram to compute NxN permanents and determinants using a similar procedure (expansion by minors), have a look at my PDF article which I posted about 4 years ago: which includes the subprogram proper and revealing examples. Regards. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
04-29-2023, 05:30 PM
(This post was last modified: 04-29-2023 05:33 PM by John Keith.)
Very nice, thanks! You seem to be 18 years ahead of me.
I tried the idea from your article regarding the explicit computation of 3 x 3 matrices. It does result in a significant speed-up for matrices larger than 6 x 6 but at a cost of doubling the size of the program. Not to mention "stackrobatics" that would make your eyes hurt! I did not consider giving the program the ability to compute determinants since the 49 and 50 can solve exact and symbolic determinants much faster. Might be useful for the 48g though. |
05-03-2023, 07:39 PM
(This post was last modified: 01-07-2024 08:06 PM by John Keith.)
The new and improved(?) version, both larger and faster. Obsolete- see post #5 below!
Does direct computation of 3 x 3 matrices and also handles 2 x 2 and 1 x 1 matrices. The program uses compiled local variables to isolate the 1 x 1 and 2 x 2 cases from the main recursive program. Real and exact matrices up to size 9 can be solved, if slowly. Complex and symbolic matrices up to size 7 or 8 can be solved, depending on the size of elements and the amount of available memory. The program does not avoid computations with zero elements because there is no fast and simple test for zero that will work with real, complex, exact integer and symbolic matrices. Code:
As before, a slightly smaller version optimized for the 49 and 50. Code:
01-07-2024, 08:27 PM
(This post was last modified: 01-24-2024 03:23 PM by John Keith.)
A new and much improved program for the HP 49 and 50 using Glynn's formula. This program is based on Albert Chan's optimization of a program by GitHub user "lesshaste". See discussion in this thread. Thanks also to Valentin Albillo, whose recent thread inspired the current flurry of activity on matrix permanents.
The program should be used in Exact mode for larger matrices to avoid overflow. Code:
Updated 2024/01/08 to clean up code. Newer version 2024/01/10, a bit smaller and simpler, now 256 bytes. Latest version 2024/01/24, slightly larger but 33% faster. |
01-24-2024, 03:40 PM
The program in post #5 above has been updated with two significant changes. Firstly, the FLASHEVAL and R~SB command have been replaced by a WHILE loop which is just as fast and only a few bytes larger. This removes the requirement for Library 256.
Second and most importantly, I realized there was a rather glaring inefficiency in the original Python program requiring a list multiplication in every iteration. That multiplication has been factored out of the loop resulting in a speedup of about 33%. The current program computes the permanent of Valentin's 12 x 12 matrix in 254 seconds (Exact mode) or 221 seconds (Approximate mode) on my 50g. |
