PRINT() to terminal last space instead of new line.
05-01-2023, 10:53 PM
Is there a way to use PRINT() sending text to the Terminal that would allow the next PRINT() command to continue where the last avaiable space was, instead of taking a new line with a new PRINT() command?
05-02-2023, 04:58 AM
RE: PRINT() to terminal last space instead of new line.
(05-01-2023 10:53 PM)matalog Wrote: Is there a way to use PRINT() sending text to the Terminal that would allow the next PRINT() command to continue where the last avaiable space was, instead of taking a new line with a new PRINT() command?Bonjour Regardez l'instruction 'Terminal', elle permet de récupérer et de modifier ce qui a été envoyé avec PRINT. Si ça peut aider. Look at the 'Terminal' instruction, it allows you to retrieve and modify what has been sent with PRINT. If it helps. Sorry for my english |
