How can I discover which version of Python I am running?
05-16-2023, 10:30 AM (This post was last modified: 05-16-2023 11:07 AM by StephenG1CMZ.)
So far I have this (tested only on Numworks):
"""XMH Explore My Host.
This version identifies which calculator you are on.
crme="""
© 2023 StephenG1CMZ
crid="XMH\nExplore My Host"+crme
try:
  import casioplot
  isCasio=True
except:
  isCasio=False
try:
  import ion
  isNumworks=True
except:
  isNumworks=False
if isNumworks:
  try:
    import os
    fork="Omega" #alternative
  except:
    fork="Epsilon" #Main
try:
  import ti_system
  isTI=True
except:
  IsTI=False
print(crid)
if isCasio:
  print("Casio")
if isNumworks:
  print("Numworks", fork)
  if fork=="Omega":
    print(os.name)
if isTI:
  print("TI")
if isCasio or isNumworks or isTI:
  isCalculator=True
else:
  isCalculator=False
  print("Unrecognised Host")
With the news that Python may be coming to the HP Android, I wonder how it might best be recognised?
Stephen Lewkowicz (G1CMZ)
05-16-2023, 12:09 PM
RE: How can I discover which version of Python I am running?
You could try something that uses sys.platform like
try:
    import sys
    try:
        if sys.platform == "HP Prime":
            IsPrime = True
        else:
            IsPrime = False
    except AttributeError:
        IsPrime = False
except ImportError:
    IsPrime = False
print("IsPrime:", IsPrime)
05-16-2023, 07:19 PM
You could also use, similar to Casio and Ti:
try:
  import hpprime
  IsPrime = True
except:
  IsPrime = False
print("IsPrime = ", IsPrime)
No need to resort to "sys" library
Günter
05-17-2023, 07:04 AM (This post was last modified: 05-17-2023 08:14 AM by StephenG1CMZ.)
Ah, so there are two alternatives.
The try import hpprime matches how the other calculators are detected.
But the prime version also has sys.platform.
That has the advantage that sys.platform will also show if the code is running on non-calculator hosts.
05-21-2023, 08:48 PM (This post was last modified: 05-21-2023 08:49 PM by StephenG1CMZ.)
I have placed a version here, using the built-in sys where it is available:
https://www.hpmuseum.org/forum/thread-19989.html
Tested only on Numworks as Python has yet to reach HP Prime Android.
