How can I store Numworks scripts? (Solved)
06-12-2023, 11:45 PM (This post was last modified: 06-13-2023 09:13 AM by StephenG1CMZ.)
I'd like to upload a few Numworks Python scripts, initially as online backup and later to share a few programs.
I had seen a My Numworks section with scripts, but I can't seem to get it to work.
When I try to add a script, I see a window but nothing I do pastes code.
If I run the online emulator instead, it pastes and runs code, but "save" seems save a session (where???), without uploading my script.
[I'm uploading from my phone, not a real calculator]
Stephen Lewkowicz (G1CMZ)
06-13-2023, 09:16 AM (This post was last modified: 06-13-2023 09:41 AM by StephenG1CMZ.)
RE: How can I store Numworks scripts? (Solved)
Solved.
When you select "add a new script", you see a window that doesn't respond.
If you rotate the phone to landscape, you see two windows.
And the new window will paste text
