DM32 firmware update
06-15-2023, 10:37 AM
DM32 v2.03: 2023-06-15
Fixes Fixed: Wrong display update during Integrate (Display is constantly repainted instead of steady INTEGRATING message) Fixed: Integration/Solve restart doesn't work Fixed: FN= setting isn't stored in statefile Fixed: Integration isn't internally terminated after an error (doesn't allow to start new integration after an error) Fixed: 'Div by 0' in Example2 of Inverse-Normal Distribution Fixed: Reflect SCI setting in Integration (Handling of errors in Integration algorithm depends on FIX/SCI mode setting) Fixed: Error in Exampe2 of "Polynomial Root Finder" Fixed: DM32 vs 32SII difference Statistics Normal Distribution Program Stack Z not the same Fixed: Wrong program size display in MEM->PGM Fixed: program edit: R/S during number input fails Fixed: In calc menus F-keys act immediately Fixed: SHOW doesn't reflect inverted dot/comma mode Fixed: Wrong display of RADIX, in inverted dot/comma mode Fixed: Remove debug numbers from header title Fixed: Stack values lost upon INPUT in program https://technical.swissmicros.com/dm32/firmware/ |
06-15-2023, 11:50 AM
(This post was last modified: 06-15-2023 11:50 AM by Namir.)
RE: DM32 firmware update
Thanks for the update. You are right, I updated the firmware and tested the integrate feature. It makes a big difference!
Namir |
