(48/49/50) Rank of Permutation
06-17-2023, 02:40 PM
(This post was last modified: 06-17-2023 02:42 PM by John Keith.)
These two programs compute the rank (lexicographic index) of a permutation, or return a permutation (as a list) given the rank. The rank assumes 1-based lists, i.e. a sorted list has the rank 1. For the HP-48, the maximum length of the permutation list is 14. For the 49 and 50, the length is limited only by memory if used in Exact mode.
The first program, PRNK, takes a list on level 1 and returns the rank as an integer. The program uses LSORT but can also use the built-in SORT command on the 48G and later. Code:
The next program, PURNK (permutation unrank) is the inverse of the program above. Given integers n on level 2 and j on level 1, returns a permutation of the numbers 1..n with rank j. The HP 49/50 version requires ListExt and should be used in exact mode. Code:
The HP-48 version is longer but still reasonably fast. It uses the program 'REL' from One-Minute Marvels as a replacement for LRMOV. Code:
06-26-2023, 12:25 PM
RE: (48/49/50) Rank of Permutation
This is a variation of PURNK that takes a sorted list on level 2 instead of an integer. The objects in the list may be of any type(s).
For instance, with the list { "apple" "banana" "cherry" "grape" } on level 2 and the number 8 on level 1, the program returns { "banana" "apple" "grape" "cherry" }. HP 49/50 version: Code:
HP-48 version: Code:
