Problem with ->HMS
08-25-2014, 04:21 PM
Problem with ->HMS
There appears to be a problem with ->HMS in Home, if the argument is between -1 and 0, e.g.,
->HMS(-0.1) returns 0 degrees 06 minutes 0 seconds, same as ->HMS(0.1). Even entering -0 degrees 6 minutes on the command line returns the positive value of 0 degrees 6 minutes. However, HMS->(-0 degrees 6 minutes 0 seconds) returns -0.1, so that is fine. Thanks for looking into that! |
08-25-2014, 07:19 PM
RE: Problem with ->HMS
Note that is purely a display thing. Calculations are just fine.
08-25-2014, 08:24 PM
True, it is a display thing (for the most part!), but annoying nevertheless, because you don't know if your result is positive or negative without some subsequent testing.
