F not working in Base number mode.
07-05-2023, 07:50 PM
Shift then Minus key "-" brings you to the Base number mode. I cannot enter F in the Hexadecimal part there, pressing X^y which is the "F" key, returns 1 in the 16 mode in there. Should that be?
07-05-2023, 08:00 PM
RE: F not working in Base number mode.
I don't know if this can help you...
https://www.hpmuseum.org/forum/thread-11231.html
07-05-2023, 08:29 PM (This post was last modified: 07-11-2023 05:39 PM by matalog.)
Thanks, that helps me to see how I can enter an F, by having the number prepared before I entered Base screen.
Every other number/letter can be entered live in Base screen, apart from F though, seems odd.
07-05-2023, 08:59 PM
(07-05-2023 08:29 PM)matalog Wrote:  Every other number/letter can be endered live in Base screen, apart from F though, seems odd.
Strange, I tested it on my Prime G2 and I have no issue entering F.
With which Prime version are you experienced this issue?
Do you have any user assignment active for the x^y key ?
07-05-2023, 10:04 PM
I have a user assignment for the x^y key! I had forgotten about this one. Thanks.
07-06-2023, 10:58 PM
Interestingly the key assignment was set to output a string that involved the number 1, after I changed it to F instead of 1, it output F. It seems that if the string output contains a viable number/letter (in this case 1 to F, for HEX) then it will insert it in the field of the Base number entry window.
