HP-75C Owner's Pac
07-10-2023, 08:43 AM
HP-75C Owner's Pac
i am looking for the HP-75C Owner's Pac especially for the PAYATTN game which i like to convert to the HP71. I did it 30 years ago, but the files are gone.
The files should not be on card, because i have only the HP71.
I found the Games II TDO file in the net and could convert it with teledisk and hpdir but it seems that the files are protected. (Lists as P file type)
My desired approach is to get the program working on emu75 and then transform it to LIF / TEXT.
Emu75 says 'restricted access', it is not possible neither to execcute nor to transform it.
Ralf
/41/48/
07-10-2023, 09:35 AM
RE: HP-75C Owner's Pac
The PAYATTN program is in the 75OwnPac.hpi volume (a regular LIF disc image) inside the 75Disks5.zip collection at the HP75 groups.io (you may have to join to download it).
The program is not protected, I loaded it in Emu75 and it seems to run fine.
J-F
07-10-2023, 10:19 AM
HI,
thank you, i found this file in the HP75 groups.io usergroup and it works now.
Thanks for your help!
Ralf
/41/48/
