Reliable info about the Prime G1 & G2 HW design?
07-16-2023, 02:58 PM
Is there some source of reliable info on the HW design of the HP Prime calcs, g1 as well as g2?
07-16-2023, 04:28 PM
RE: Reliable info about the Prime G1 & G2 HW design?
(07-16-2023 02:58 PM)n3mmr Wrote:  Is there some source of reliable info on the HW design of the HP Prime calcs, g1 as well as g2?
imho your are in the right place, just use "search"
07-16-2023, 04:29 PM (This post was last modified: 07-16-2023 04:36 PM by Jean-Baptiste Boric.)
This is what I can recall at the moment, there might be other developments I'm not aware of or that I forgot about.
Regarding the HP Prime G1:
Regarding the HP Prime G2:
*my recollection is that at some point early, pre-release firmware versions predating the unlock-style wizard did boot, it might've improved since then
Edit: if it can boot on a physical calculator or if it can run the official firmware then I consider it to contain reliable info about HW design, even if it's in source code format.
07-17-2023, 08:34 AM
Thank you, mr Boric!
