HP 41CV - R/S Key in Programs
07-20-2023, 02:12 PM
Is there any known issue with the R/S key not registering consistently when running a program? Sometimes it takes several presses after a prompt, stop, etc.
The R/S key physically seems to work fine. It has no issues when just entering it as (for instance) and instruction in a program, or otherwise.
The issue seems more evident when running a program from a ROM. In this case I have been using the Real Estate ROM.
Thanks!
07-20-2023, 03:01 PM
RE: HP 41CV - R/S Key in Programs
Is it a normal HP-41C/CV/CX or a DM41X?
I have noticed that the DM doesn't recognize R/S when printing (with IR), then you have to press several times before it is accepted.
Cheers,
[35/45/55/65/67/97/80 21/25/29C 31E/32E/33E|C/34C/38E 41C|CV|CX 71B 10C/11C/12C/15C|CE/16C 32S|SII/42S 28C|S 48GX/49G/50G 35S 41X]
07-20-2023, 03:25 PM
A normal HP-41CV.
May be just an idiosyncrasy in my calculator.
Thanks again!
Anthony
