Canon Pocketronic II Charger CH-1
07-23-2023, 04:38 PM
Dear All,
I was able to purchase a Pocketronic II, unfortunately without a power supply. Does anyone know how the plug of the associated power supply Canon CH-1 is assigned? Is the positive pole on the pin in the middle or outside?
Every hint is welcome - thank you in advance.
Best regards
Karl
07-23-2023, 06:49 PM
RE: Canon Pocketronic II Charger CH-1
The manual says the charger model number is CH-1:
http://www.datamath.net/Manuals_Others/P...-II_US.pdf
TIP: Look on eBay for pictures:
https://www.ebay.com/itm/223694211680
It is 15V center negative. Keep in mind that this will be an unregulated supply which will put out ~19V with no load. Charging the batteries will load the supply dropping the voltage to ~15V. Given that the guys above is selling NOS charges for $4 that might not be a bad option if you care in USA.
07-24-2023, 08:35 AM
Hi Jeff,
thanks a lot for your reply. The photo in the auction is a good hint, but the type of the charger is "CH-1A". What is the difference between the types "CH-1" and "CH-1A"?
Thank you very much in advance.
Best regards
Karl
07-24-2023, 01:00 PM
Go to eBay and search for "Canon charger CH-1", compare the pictures. This will answer your question.
