wp34s nspire port
08-28-2014, 05:08 AM
wp34s nspire port
It would appear that the wp34s emulator has been ported to the nspire:
http://www.omnimaga.org/ti-nspire-projec...n-nspire!/
Since, I finally got around to picking up a CX CAS(which thank the f'ing lord came with OS 3.6 and hence is ndless capable) I'll have to try it out ... eventually...
Screenshots look legit to me... more the bottom one than the top...
(Man, the more I look at these ancient RPN type calcs the more I think register based rather than "stack" with limited XYTZ(and maybe a few more) v. only memory limited...)
08-28-2014, 05:41 AM
RE: wp34s nspire port
Yes, you can find more info here
Greetings,
    Massimo
