( Free42 , DM42 ) Overflow is not trapped of basic matrix arithmetic,
08-12-2023, 12:44 PM
Dear all
I came across something strange with overflow or out range error reporting for basic matrix arithmetic. With flag 24 clear and 25 clear, any overflow should result in aborted calculation and a warning. However consider this simple example where matrix multiplication and overflow is not trapped, it only result in elements being silently replaced by maxreal DM42 or Free42 in decimal mode flag 24 clear, flag 25 clear 1 ENTER NEW 8E6144 + STO M Matrix multiplication: RCL M ENTER x result in numbers being silently replaced by maxreal ( 9.99999E6144) Matrix scaling: RCL M 10 x if you scale by 10 you get an error as you should Matrix addition: RCL M ENTER + for addition you get an error as it should. When in binary mode the limits are different but with same inconsistency Can anyone check this on a real hp42s? It is not often you get overflow with the new large floating point range, but still surprising to find this after all the use for many years. Best regards Gjermund |
08-12-2023, 06:49 PM
(This post was last modified: 08-12-2023 09:16 PM by rprosperi.)
RE: ( Free42 , DM42 ) Overflow is not trapped of basic matrix arithmetic,
A 42S cannot handle the value 8E6144...
MAXREAL on the 42S is 9.99999999999 E499 So I tried using 8E499 in the above set of steps but it never yields an error. I'm pretty sure 8E499 is not the right value, but not sure what you think the analogous value to use should be. --Bob Prosperi |
08-12-2023, 10:55 PM
Free42 3.0.15 (the one in the DM42) does indeed not catch that, but version 3.0.20 and the brandnew 3.0.21 do.
41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
08-13-2023, 10:06 AM
(This post was last modified: 08-13-2023 10:23 AM by Werner.)
Update: in Free42, it's a Preferences menu option ;-) it's clear per default, as that is the 42S behavior
in the DM42 you can't change it. It turns out that this is 42S behavior. 42S matrix operations act as if F24 is set all the time, e.g. : (with F24 clear) 1 ENTER NEWMAT 9E499 + ENTER + EDIT yields 9.999..E499, MAXREAL Don't know which version of Free42 changed it, it isn't in the history. At the very least, the DM42 acts as the real 42S in this regard. I'll ask Thomas about it Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
08-13-2023, 10:37 AM
Hi Werner,
thanks for investigating, and the reminder of Free42 preferences setting. BR Gjermund |
