V41 R9I won´t start on windows 11
08-24-2023, 09:44 AM
(This post was last modified: 08-24-2023 09:47 AM by Ángel Martin.)
I´m having issues with V41 R9I on windows 11.
The application won´t start, throwing an error mssage like ¨Parallel configuration not correct¨.- Any idea of what´s the issue here? "To live or die by your own sword one must first learn to wield it aptly." |
08-24-2023, 09:58 AM
(This post was last modified: 08-24-2023 10:00 AM by Massimo Gnerucci.)
RE: V41 R9I won´t start on windows 11
(08-24-2023 09:44 AM)Ángel Martin Wrote: I´m having issues with V41 R9I on windows 11. My R9I is running fine under Win11. Looks like your problem could be due to missing/corrupt Microsoft Visual C++ Redistributable versions. Maybe only a reinstall of this is needed... Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
08-24-2023, 01:58 PM
(This post was last modified: 08-24-2023 01:59 PM by Ángel Martin.)
(08-24-2023 09:58 AM)Massimo Gnerucci Wrote: My R9I is running fine under Win11. Thanks Massimo, indeed that was the issue. I had forgotten all about this, which I believe had also done once before on a win'10 machine. Best, ÁM "To live or die by your own sword one must first learn to wield it aptly." |
