faster DM42 Hitomezashi algorithm
08-27-2023, 03:45 PM
On a 1/23/22 post entitled "Calculator Graphics Drawing Benchmark", the Hitomezashi algorithm implemented for the DM42 takes 18.7 seconds on a 400x240 screen. Because the DM42 does not have a line command, a lot of time is consumed drawing lines pixel by pixel. However, using the AGRAPH command, this can be greatly increased in speed. There is the AGRAPH limitation of drawing 8 pixel vertical lines, however, a 200x120 screen can be used if longer looking lines are desired (still limited to a maximum of 8 pixels size). Store the size in the variable S (using a number from 3 to 8). On line 4, a 3 specifies a 400x240 screen, and a 2 specifies a 200x120 screen. I used the original benchmark posting code as a reference, but wrote my own implementation of the Hitomezashi algorithm, to make use of the AGRAPH command.
Here are the times using an unscientific method of a stopwatch:
400x240 using USB cable:
S=4 - 3.55 sec.
S=8 - 1.42 sec.
400x240 using battery:
S=4 - 8.55 sec.
S=8 - 2.58 sec.
00 { 230-Byte Prgm }
01▸LBL "HT"
02 "GrMod"
03 ASTO 03
04 3
05 STO IND 03
06 RCL "S"
07 1ᴇ3
08 ÷
09 STO "S1"
10 CLA
11▸LBL 01
12 1
13 XTOA
14 ISG "S1"
15 GTO 01
16 RCL "ResX"
17 1ᴇ3
18 ÷
19 RCL "S"
20 2
21 ×
22 1ᴇ5
23 ÷
24 +
25 STO "X1"
26 RCL "ResY"
27 1ᴇ3
28 ÷
29 RCL "S"
30 1ᴇ5
31 ÷
32 +
33 STO "A"
34▸LBL 02
35 RAN
36 2
37 ×
38 IP
39 RCL "S"
40 ×
41 RCL "X1"
42 +
43 STO "B"
44▸LBL 04
45 RCL "A"
46 RCL "B"
47 AGRAPH
48 ISG "B"
49 GTO 04
50 ISG "A"
51 GTO 02
52 CLA
53 2
54 RCL "S"
55 Y^X
56 1
57 -
58 XTOA
59 RCL "ResY"
60 1ᴇ3
61 ÷
62 RCL "S"
63 2
64 ×
65 1ᴇ5
66 ÷
67 +
68 STO "Y1"
69 RCL "ResX"
70 1ᴇ3
71 ÷
72 RCL "S"
73 1ᴇ5
74 ÷
75 +
76 STO "B"
77▸LBL 08
78 RAN
79 2
80 ×
81 IP
82 RCL "S"
83 ×
84 RCL "Y1"
85 +
86 STO "A"
87▸LBL 10
88 RCL "A"
89 RCL "B"
90 AGRAPH
91 ISG "A"
92 GTO 10
93 ISG "B"
94 GTO 08
95 END
