IHP48 APP IOS
09-13-2023, 08:21 AM
IHP48 APP IOS
Hi to all staff HP !
I've a problem with this APP , i would like to use this APP with EQUATION LIBRARY like my old physic calculator any one can help me ?
Thanks a lot !
09-13-2023, 12:26 PM
RE: IHP48 APP IOS
If you referring to Equation Library items in the "HP Solve Equation Library" card, most of it is built into the HP-48G (no Periodic Table), HP 49G and HP 50G series that iHP48 can emulate. Simply use the "New..." option from iHP48 menu to create one of those models.
09-18-2023, 12:22 PM
RE: IHP48 APP IOS
(09-13-2023 12:26 PM)Steve Simpkin Wrote:  If you referring to Equation Library items in the "HP Solve Equation Library" card, most of it is built into the HP-48G (no Periodic Table), HP 49G and HP 50G series that iHP48 can emulate. Simply use the "New..." option from iHP48 menu to create one of those models.
HI STEVE
can you help me to set IHP48 APP with Equation Library , i tryed to insert in menu New my model of Iphone but there is not my model so how i can do now ?
09-19-2023, 12:18 AM (This post was last modified: 09-19-2023 12:21 AM by Steve Simpkin.)
RE: IHP48 APP IOS
Here are the steps I used to create a new HP-48G in the iHP48 app.
1. In iHP48, touch on the LCD display area to open the main Menu.
2. If needed, touch Save (or Save as...) to save your current model calculator.
3. Touch Close to close the current model.
4. Touch New... to open the Choose Skin menu.
5. Touch HP48G to choose the HP48G skin.
6. Touch the top skin file in the list to choose the "Emu48 Real 48GX Big LCD" skin. Touch OK.
7. Touch the "Back" control (in the upper-left corner) to show the new HP-48GX calculator.
8. Press the No soft menu key to choose not to try and recover memory.
8. Press the Right-Shift button followed by the 9 key (EQ LIB). This will open the Equation Library as shown in the screenshot below.
09-19-2023, 05:54 PM
RE: IHP48 APP IOS
(09-19-2023 12:18 AM)Steve Simpkin Wrote:  Here are the steps I used to create a new HP-48G in the iHP48 app.
sorry but i'm bocked at 6 step because i've not Real 48Gx Big LCD skin.
I use smartphone IOS model Iphone 7 perhaps is formatted in different mode i think
09-19-2023, 07:38 PM
RE: IHP48 APP IOS
Sorry. You have to download skins and ROMs first using the Fetch.. option from the iHP48 Menu. When you touch Fetch... in the main Menu, you will see options to download Calculator Full Packages, Skin Collections, Calculator ROMs and other items. I think downloading the "HP 48G/GX Graphic Calculator" package and maybe the "Real HP48G" skins might be enough for my instructions. I ended up downloading them all for the most options.
09-20-2023, 07:10 AM
RE: IHP48 APP IOS
(09-19-2023 07:38 PM)Steve Simpkin Wrote:
(09-19-2023 05:54 PM)$Calculus_HP Wrote:  sorry but i'm bocked at 6 step because i've not Real 48Gx Big LCD skin.
Thanks a lot !
I resolved this problem because now i have different alt keyboard and i need to press arrow right and number 3 with EQ LIB fantastic !
09-20-2023, 07:30 AM
RE: IHP48 APP IOS
(09-20-2023 07:10 AM)$Calculus_HP Wrote:
(09-19-2023 07:38 PM)Steve Simpkin Wrote:  Sorry. You have to download skins and ROMs first using the Fetch.. option from the iHP48 Menu. When you touch Fetch... in the main Menu, you will see options to download Calculator Full Packages, Skin Collections, Calculator ROMs and other items. I think downloading the "HP 48G/GX Graphic Calculator" package and maybe the "Real HP48G" skins might be enough for my instructions. I ended up downloading them all for the most options.
Thanks a lot !
it's all ok but there isn't minehut game !
can you explain me why ?
09-20-2023, 07:35 AM
RE: IHP48 APP IOS
(09-20-2023 07:30 AM)$Calculus_HP Wrote:
(09-20-2023 07:10 AM)$Calculus_HP Wrote:  Thanks a lot !
and also periodic chemical table
09-20-2023, 09:41 AM
RE: IHP48 APP IOS
(09-20-2023 07:35 AM)$Calculus_HP Wrote:
(09-20-2023 07:30 AM)$Calculus_HP Wrote:  it's all ok but there isn't minehut game !
For the HP-48GX, HP included most of the contents of the "HP Solve Equation Library" card but not all. They left out at least the Periodic table and Minecraft game. These items were added into later HP models.
I recommend creating an HP 50g in iHP48. In the HP 50g you can press the APPS button, scroll down to item 13 and press ENTER for the Periodic Table.
Press the APPS button, scroll down to item 12 and press ENTER for the Equation Library. This will open the Equation Library Menu as shown below. The Equation Library can be accessed in item 1. The Minehunt game is under item 4 (UTILS..).
09-20-2023, 11:51 AM (This post was last modified: 09-20-2023 01:12 PM by $Calculus_HP.)
RE: IHP48 APP IOS
(09-20-2023 09:41 AM)Steve Simpkin Wrote:
(09-20-2023 07:35 AM)$Calculus_HP Wrote:  and also periodic chemical table
now 50g it's good but the graphic isn't better solution althought there is util in the menu and also minehunt game , it's very easy !!!
09-20-2023, 12:55 PM
RE: IHP48 APP IOS
(09-20-2023 09:41 AM)Steve Simpkin Wrote:  For the HP-48GX, HP included most of the contents of the "HP Solve Equation Library" card but not all. They left out at least the Periodic table and Minecraft game. These items were added into later HP models.
The Minehunt game was actually included in all 48GX (and other 48G series) calculators. It was only the Periodic Table that was excluded.
09-21-2023, 02:02 AM
RE: IHP48 APP IOS
I did not know that but was able to find that easy enough once I did. Thanks Eric!
For reference, here is the missing HP Periodic Table Library for the HP-48G series on Eric's hpcalc.org site. This is a RAM-based version of the Periodic Table application that was originally distributed in the HP 82211A HP Solve Equation Library Card.
You can find more Periodic Table programs for the HP-48 at the same site:
https://www.hpcalc.org/search.php?query=...ble&hp48=1
09-21-2023, 07:29 AM
RE: IHP48 APP IOS
(09-21-2023 02:02 AM)Steve Simpkin Wrote:
(09-20-2023 12:55 PM)Eric Rechlin Wrote:  The Minehunt game was actually included in all 48GX (and other 48G series) calculators. It was only the Periodic Table that was excluded.
I'm satisfied because we have a good understanding !!!
I would like to know if is possible to install in this app a customer directory.
Thanks a lot !
09-21-2023, 11:12 AM
RE: IHP48 APP IOS
Thanks a lot !
09-21-2023, 11:56 AM (This post was last modified: 09-21-2023 11:57 AM by Steve Simpkin.)
RE: IHP48 APP IOS
(09-21-2023 11:12 AM)$Calculus_HP Wrote:  ...
Perhaps one of these might be what you are looking for (for the HP-48G models):
https://www.hpcalc.org/details/26
https://www.hpcalc.org/details/65
There are a lot more listed at hpcalc.org
HP 48 PIMs (Personal Information Managers)
09-21-2023, 02:04 PM
RE: IHP48 APP IOS
I'm interested to install on my smartphone IOS Iphone under folders of this APP
if is possible !!
Thanks a lot
09-22-2023, 06:58 AM
RE: IHP48 APP IOS
(09-21-2023 02:04 PM)$Calculus_HP Wrote:
(09-21-2023 11:56 AM)Steve Simpkin Wrote:  Perhaps one of these might be what you are looking for (for the HP-48G models):
if is possible !!
Thanks a lot
how i can do to install this file ?
09-22-2023, 11:50 AM
RE: IHP48 APP IOS
(09-22-2023 06:58 AM)$Calculus_HP Wrote:
(09-21-2023 02:04 PM)$Calculus_HP Wrote:  I'm interested to install on my smartphone IOS Iphone under folders of this APP
if is possible !!
Thanks a lot
I think but i'm not sure , there is load object to load right file in a path folder.
Are you agree with me ?
09-23-2023, 03:27 PM
RE: IHP48 APP IOS
Someone can help me with EQ LIB ?
Thank a lot !
