Poll: Would you like a vector-based TTF font based on the tiny 4x6 UFL 1 font?
Yes
No
Unsure
[Show Results]
UFL 1 font...
09-14-2023, 04:51 PM (This post was last modified: 09-14-2023 05:08 PM by Jonathan Busby.)
UFL 1 font...
I've become interested in the UFL 1 4x6 tiny font after a discussion with a fellow HP48 friend and hacker. I'm in the process of creating a vector TTF for this font. I'm using lines instead of Bezier splines, but I may switch to splines.
As part of this project, I was prompted to render the original UFL 1 font on my 4K UHD display. To that end I've created a small FreeImage library utility function in ISO / ANSI / POSIX C that renders an input string into a properly sized and column wrapped PNG file.
Here's an example of the rendered raw UFL 1 4x6 tiny font, although enlarged ( with no interpolation ) by a factor of four :
[Image: ufl-render-test-1-scaled-1.png]
And here's the original ( also attached... ) :
[Image: original.png]
( The small C app is attached... It's also been uploaded to HPcalc.org, but it will probably be a while before Eric updates the site... )
What are your thoughts? Any helpers, recommendations or tips for the TTF font would be welcome.
Jonathan
Attached File(s) Thumbnail(s)
.zip  ufl-render-2.zip (Size: 12.07 KB / Downloads: 7)
Aeternitas modo est. Longa non est, paene nil.
09-14-2023, 06:48 PM
RE: UFL 1 font...
(09-14-2023 06:34 PM)Massimo Gnerucci Wrote:  Of course you know there is FONTMINI.TTF
Didn't know that Smile Thanks for the tip Smile I've looked at said TTF font file and it looks like a quasi-bitmapped font that doesn't use any type of interpolation, such as Bezier splines or lines... So, it can be improved upon...
Jonathan
09-15-2023, 02:31 PM
RE: UFL 1 font...
In the past I have used FontForge to create some fonts based on bitmapped fonts.
FontForge has a scripting interface so that you can write a e.g. Python program to read a bitmap font and recreate the pixels as vector objects.
This is at least a good starting point as creating 256 glyphs is quite some work.
Of course this automatic process does not included details like hints.
Martin
09-17-2023, 04:54 PM
RE: UFL 1 font...
(09-15-2023 02:31 PM)Martin Hepperle Wrote:  In the past I have used FontForge to create some fonts based on bitmapped fonts.
Thanks for the info Smile I'm not quite sure if anyone really wants a UFL 1 minifont based vector
TTF, at least from the equivocal poll. But, it's nice to know that there's a scripting
interface available -- although I prefer Perl Smile
Quote:This is at least a good starting point as creating 256 glyphs is quite some work.
Well, in the UFL 1 minifont, a large portion of those 256 bitmaps are blank.
Quote:Of course this automatic process does not included details like hints.
Yep. The devil's in the proverbial details as they say...
Jonathan
P.S. Attached as an updated small C app that renders the UFL 1 minifont but correctly handles newlines... I've also uploaded it to HPcalc.org...
Attached File(s)
.zip  ufl-render.zip (Size: 50.88 KB / Downloads: 5)
