(HP15C CE) 3 Med Calcs I always carry with me
09-20-2023, 06:13 PM
Since I bought HP15c CE it's always in my pocket for 3 essential medical calculations, and tried to use only the stack without STOring and RCL (recalling) additional registers. First the Creatinine Clearance (Cockcroft-Gault) formula which is useful for almost all drugs dosages for people with kidney failure. Second is the Body Surface Area (Takahira). As I use meters and kilograms for height and weight, the height is always a very small number and I don't bother to remember the order to put them on the stack, the program figures it out. And last the Polymyxine dosage formula for initial and subsequent doses with the results on x and y registers.
Creatinine Clearance (Cockcroft-Gault) Sex (1=male, 2=female) ENTER, Age (Years) ENTER, Weight (Kg) ENTER, Cr (mg/dL) fC. Code:
Body Surface Area (Takahira) Weight ENTER, Height fA. Or vice versa! Code:
Polymyxine Dose Calculator Creatinine Clearance ENTER, Weight (Kg) ENTER, Desired consentration (mg/dL) fB For MIC<1 the desired consentration is 2mg/dL Code:
09-20-2023, 09:52 PM
RE: (HP15C CE) 3 Med Calcs I always carry with me
For body surface formulae:
https://en.m.wikipedia.org/wiki/Body_surface_area |
