[HP71B] How to activate VIDEO output AND PRINTER (ILPER)
09-21-2023, 11:26 AM
(This post was last modified: 09-21-2023 11:26 AM by floppy.)
currently using EMU71 with ILPER and VIDEO80, the commands and outputs appears on the green screen. Is it possible to have an output in the PRINTER area of ILPER, too? (for having the copy function of the printed text; which is not possible in the Video80 screen). If not, the switch from VIDEO80 to PRINTER can probably be made with the TCP/IP setup. HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
09-21-2023, 02:56 PM
RE: [HP71B] How to activate VIDEO output AND PRINTER (ILPER)
You cannot have the output go to both (AFAIK) but you can direct output to IL-Per's virtual 'printer' window by using the command DISPLAY IS PRINTER, so you can then copy.paste, etc.
--Bob Prosperi |
09-21-2023, 03:35 PM
(This post was last modified: 09-21-2023 03:44 PM by Sylvain Cote.)
First deactivate display/printer redirection.
Code: DISPLAY IS * ! deactivate display redirection Assuming HP-IL configuration
Send a string to the display at address #1 and to the printer at address #3 Code: SEND UNT UNL LISTEN 1,3 MTA DATA "a string" UNT UNL Send multiple lines Code: SEND UNT UNL LISTEN 1,3 MTA commands description Code: UNT ! deactivate the current talker Sylvain Côté |
09-21-2023, 03:40 PM
(09-21-2023 02:56 PM)rprosperi Wrote: You cannot have the output go to both (AFAIK) but you can direct output to IL-Per's virtual 'printer' window by using the command DISPLAY IS PRINTER, so you can then copy.paste, etc.Ok (I love that green screen). HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
09-21-2023, 03:45 PM
(09-21-2023 03:35 PM)Sylvain Cote Wrote: Assuming that the first display/printer is at address 1 and that the second display/printer is at address 2. Thanks. My understanding (correct it if wrong): the sending to both device is possible but has to be controlled. & the output of the HP71B screen (mirror of it) can be done only on the currently activated device. HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
09-21-2023, 03:48 PM
(This post was last modified: 09-21-2023 03:52 PM by Sylvain Cote.)
(09-21-2023 03:45 PM)floppy Wrote: Thanks. My understanding (correct it if wrong): the sending to both device is possible but has to be controlled. & the output of the HP71B screen (mirror of it) can be done only on the currently activated device.When you go into manual mode, the automatic redirection must be deactivated because one will interfere with the other. To understand how HP-IL works, activate ILPER/pyILPER scope window and with the HP-IL reference manuals, learn the HP-IL protocol/behavior. Sylvain Côté |
09-21-2023, 04:12 PM
DISPLAY IS * deactivated the screen.
Now, how to activate the printer? (beginner at work..) See attachment. HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
09-21-2023, 05:25 PM
(This post was last modified: 09-21-2023 10:26 PM by Sylvain Cote.)
(09-21-2023 04:12 PM)floppy Wrote: Now, how to activate the printer? (beginner at work..)Please read HP 82401A HP-IL Interface Owner's Manual getting started section. Edit: Section 2 - Printer and Display Operations - will answer your questions on the subject. Sylvain Côté |
09-22-2023, 07:08 AM
(This post was last modified: 09-22-2023 07:21 AM by floppy.)
Thanks. In the BASIC prompt, following command made it
DISPLAY IS :PRINTER HP71 4TH/ASM & Multimod, HP41CV/X & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X, HP75D |
