Program without using variables?
10-03-2023, 09:04 PM
I am going down a few rabbit holes at the moment and I am exploring the idea of how to take numbers from the stack and use them in a program without storing them to a variable.
Yes, I know about local variables -> a b /<< a b + />> and I use them a lot.
The program I am writing now has six soft menu keys. 1 - 4 store a number from the stack into a variable. 5 executes the program. 6 cleans the variables from memory when I am done evaluating different numbers.
My first thought was to use a list. I place a list on the stack and when I press soft menu keys 1-4 it would store that number in the list on the stack in the appropriate order. This worked well, minus having to have the list on the stack.
Is there a different way to store variables without committing them to memory?
HP48GX, HP42s and DM42.
10-04-2023, 02:39 AM
RE: Program without using variables?
argc, argv[ ] ?
10-04-2023, 12:29 PM
Try storing numbers in a matrix.
10-04-2023, 05:53 PM
Find CMAT on hpcalc.org.
"CMAT is an HP48 program for performing operations on columns of a
matrix. CMAT iterates over each row of the matrix, treating the n
columns of the matrix as if they were variables named C1, C2, ...
Cn, or, optionally, as if they were named with user-specified
names."
10-04-2023, 09:12 PM
(10-04-2023 05:53 PM)MNH Wrote:  Find CMAT on hpcalc.org.
names."
Does a matrix allow (x,y) points to be stored in one position?
What do you use as a data collector these days? I used an HP48GX like most everyone in the early 2000s. I still have my gun and 48 with cards.
10-04-2023, 10:26 PM
(10-04-2023 09:12 PM)DM48 Wrote:  Does a matrix allow (x,y) points to be stored in one position?
Yes, if you use a complex matrix. The commands R\->C and C\->R can be used to combine two real matrices into a complex matrix and vice versa.
10-05-2023, 12:38 AM
Fascinating!
10-05-2023, 11:38 AM
(10-04-2023 09:12 PM)DM48 Wrote:  What do you use as a data collector these days?
Topcon FC-5000 with MAGNET Field software.
10-05-2023, 11:47 AM
(10-04-2023 10:26 PM)John Keith Wrote:  Yes, if you use a complex matrix.
Could DM48 use a 3-D vector to store (x,y,z) points?
10-05-2023, 02:51 PM
(10-05-2023 11:47 AM)MNH Wrote:  Could DM48 use a 3-D vector to store (x,y,z) points?
Sure, or an n X 3 matrix to store a collection of points. The 48G has commands for extracting, inserting and replacing rows so that should be fairly easy and efficient.
10-07-2023, 02:26 AM
This post sparked a memory of a program that I used to use.
Please go to page forty-one of the manual. You will see that the author of the program uses a matrix to store points.
10-20-2023, 01:04 PM
Quote:Is there a different way to store variables without committing them to memory?
Keep in mind that the numbers are in memory whether they're on the stack or in a variable. The variable takes a little more space for the name and some overhead.
What you're doing sounds to me like a classic example of what directories for are. Create a directory for the program to run in. Store the variables in that directory. I don't recommend putting them on the stack because the user might modify the stack between pressing the soft keys.
