Electrical Units Conversion on Plus 42`
10-08-2023, 09:59 PM
Does anybody know how to calculate the different electrical units with a given set of other units in Plus42?
10-09-2023, 07:39 PM
RE: Electrical Units Conversion on Plus 42`
(10-08-2023 09:59 PM)codycbradio Wrote:  Does anybody know how to calculate the different electrical units with a given set of other units in Plus42?
Pretty much the same way you do other units.
Using the simplest example (length):
[Units] [Leng]
10 [enter]
[m] => (results in) 10_m on stack
1 [enter]
[in] => 1_in (in x register), 10_m (in y register).
[f] [UNIT.FCN] [Conv]
x: 393.7_in
Just make sure your units are compatible.
Farads are not convertible to Newton-meters per second squared.
Hope this helps!
Daily drivers: 15c, 32sII, 35s, 41cx, 48g, WP 34s/31s. Favorite: 16c.
Latest: 15ce, 48s, 50g. Gateway drug: 28s found in yard sale ~2009.
10-09-2023, 07:54 PM (This post was last modified: 10-09-2023 07:55 PM by johnb.)
This probably does not need saying in this venue, but I'll say it anyway.
(Unless you know tricks with the 42 that I don't -- which is pretty likely!) you have to understand the units you're working with. For example, if you have a simple 14 ohm resistive circuit and measure 12 amps going through it, E=IR gives you 168 volts, but Plus 42 will give you 168 amp-ohms, which you'd need to convert using the simple steps in my prior post. Same with simple resistive power, if you want P=EI and just entered 12_A x, you'll get 2,106_A^2*ohms, which you'd need to convert to watts.
Unless there's a trick that someone knows to get it to automatically reduce [funky] amp-ohms to [sane] volts, and so forth. I'm guessing there is one?
