Seeking header pin size recommendation
10-11-2023, 09:56 PM
Yesterday I built a DRAM Arduino 4164 & 41256 Memory Chip Tester (it works!), and a PLA20V8 Commodore 64 PLA Replacement solution. Both projects required header pins. I used 2.54mm for both. They work great for the Arduino connection (which is what they are designed for), but somewhat damage the sockets on a Commodore 64. I had to crimp the original PLA chip pins inward to get the chip to make contact with the socket after I tested the PLA20V8 solution (which works great). I want to build more PLA20V8's, but I need a better header pin size.
Any help is appreciated.
Joe
