Reading USBRecv Problem
10-12-2023, 08:53 PM (This post was last modified: 10-12-2023 09:04 PM by toml_12953.)
I'm trying to read the data from a USB keyboard continuously.
Using the program below, I get
USBKBD Error: Bad
argument type
The same USB commands work on the Home screen just fine. All I want to do is stay in the loop until a key is pressed on the keyboard then print the HID data. What am I doing wrong?
EXPORT USBKBD()
LOCAL A:={0,0,0,0,0,0,0,0};
USBOpen(1084,8467);
WHILE A=={0,0,0,0,0,0,0,0} DO
  A:=USBRecv;
PRINT(A);
END
Tom L
Cui bono?
10-12-2023, 09:25 PM
RE: Reading USBRecv Problem
USBRecv() returns an (empty) list.
Don't stick that in 'A'
ie A:={1,2,3} won't work well..
10-12-2023, 09:52 PM (This post was last modified: 10-12-2023 10:20 PM by toml_12953.)
(10-12-2023 09:25 PM)gehakte_bits Wrote:  USBRecv() returns an (empty) list.
I got the following working. Now all I need to do is make a lookup table to print the character typed rather than the HID list. This code will work no matter what keyboard you use. My first draft would only work with one brand/model.
EXPORT USBKBD()
LOCAL A:={}, B:={};
PRINT();
B:=USBOpen();
USBOpen(B(1,1),B(1,2));
WHILE 1 DO
  REPEAT
    A:=USBRecv;
  UNTIL length(A)>0 AND A(3)≠0
  PRINT(A);
Tom L
Cui bono?
10-13-2023, 12:01 PM (This post was last modified: 10-13-2023 01:55 PM by toml_12953.)
OK, here's the latest version. It correctly handles A-Z and a-z but no special characters and no Caps Lock.
EXPORT USBKBD()
  LOCAL A:={};
  PRINT();
  A:=USBOpen();
  USBOpen(A(1,1),A(1,2));
  WHILE 1 DO
    REPEAT
      A:=USBRecv;
    //PRINT(A);
    IF A(1)==2 OR A(1)==32 THEN
      PRINT(CHAR(A(3)+61));
    ELSE
      PRINT(CHAR(A(3)+93));
Tom L
Cui bono?
