Rivet removal tip when replacing HP-41 flex-PCB
10-15-2023, 08:26 AM
When replacing the HP-41 flex-PCB with one of Diego's replacements it is hard to remove the rivets between the flanges using an exacto knive.
I find it handy to use a carving tool with the blade on the front side. Named "small mouth"
here in the second picture.
Andi
10-15-2023, 03:59 PM
RE: Rivet removal tip when replacing HP-41 flex-PCB
Hi Andi,
And thanks for the useful tip. ;-)
Best from Caribbean.
Diego.
"Do not suppose, check it twice."
10-15-2023, 04:04 PM
(10-15-2023 08:26 AM)AndiGer Wrote:  I find it handy to use a carving tool with the blade on the front side. Named "small mouth"
There are similar blades for XActo knives as well.
https://www.amazon.com/DIYSELF-Upgrade-P...ef=sr_1_23
